jmwi
    56
About jmwi
  • Birthday June 11
    South Central Wisconsin
352 profile views
  1. Thank you. I appreciate it. Jesse
  2. Sounds like you have everything like it should be, maybe it is the speed of the drum as bkorth said.
  3. Yes the brush is up for corn, wired down for beans. Make sure that your seed level is high enough in the seed drum. I had trouble with my 950 not planting right because I didn't have enough seed in the drum.
  4. The hose that runs from the fuel filters to the injection pump on my 966 is getting bad. Is that a special hose ? Where is the best place to get that hose ? Thanks, Jesse
  5. Sorry for your loss.
  6. How often should the Hydro filters be changed on a 966 hydro ? I used to change them every year when I used the tractor more, but now I only use the tractor about 50 hours a year. Does anyone know how many hours they are suppose to be changed at ? Thanks, Jesse
  7. I checked into switching my 1066 from tilt steering to non tilt last fall. The salvage yards wanted around $ 1000.00 just to exchange all the parts that I needed. They wanted all of the parts that I had to change. Jesse
  8. I am rebuilding the seat suspension on my 1066. Where is the best place to buy the round rubber seat springs, part number 380712r1 ? Thanks
  9. What is the best way to fix a clutch pedal that has a lot of side to side play on a 1066 ? Is the bolt that the pedal pivots on threaded into a hole in the transmission or is there a nut on the backside somewhere ? Thanks.
  10. I have a 1066 with tilt steering that is really loose. I want to change it to the regular steering. What parts do I need to convert it to regular steering ? Thanks
  11. I am looking at buying either a 1066 or 1466. What is different between the two, other than horsepower. Thanks, Jesse
  12. I believe the 560 gas has a 263 engine not a 282. Jesse
  13. I am finding out that there are a number of laws that apply to this situation. Whether or not they are going to be enforced and by whom remains to be seen.
  14. They won't say .
  15. I have a Central Boiler that I have had for 15 years. Very simple, trouble free operation. Jesse
