caseih3294
    27
About caseih3294
  • Birthday December 15
    ontario
    case ih 3294,ih 886, ih 574, ih super c, 1660
221 profile views
  1. Hex driver size needed
    5 8s allan key should work or hex socket
  2. ih 886 problem
    hi guys have a 1979 886 and went to turn the P.T.O on and nothing, bought the tractor in may and P.T.O worked fine? the lever go's into the on position OK. Any ideas?
  3. ih 886 problem
  4. 574 IH info needed please
    the pedel next to your hydraulic lever is your diff. lock and if im correct the two above that is your 3 pth draft control and up and down control
  5. ih 886 question
    hi guys I bought a new to me 886 and just have some electrical questions it has the digital dash when I first turn on the tractor no rpm will show the fan wont blow and the radio wont work. but after its been running for a bit the rpm will flicker on but not correct showing im running 700 rpm which is incorrect and also the radio will work and the fan will blow (not cold) but will blow after a while of running -- fuel gauge, oil pressure gauge and that will work right away . Any thoughts thanks
  6. bean planter converted into corn planter?
    Ok thanks for the information and yes it has the no till ccoulters
  7. bean planter converted into corn planter?
    right now the planter is a 7/20", I was thinking a 300 was a little small, I was thinking more 500 or two 300s. but what about the depth and spacing, hard to change? haven't been around many bean planters just considering if changing it to a 6/30" corn would be an in-exspensive way of making one. those bean planters are a lot cheaper than a stock corn planter
  8. not ih. But would it be possible to convert a 7000 john deere 7 row bean planter into a 6 row 30" corn planter. I would imagine all you need to do is take off one or two row units and move them around. How about the fertilizer it already has a 300 gallon tank I believe. Would that be big a worth while size or would it be better converting it to dry. Any help or opinions greatly appreciated Thanks
