Farmall M Drawbar For Pulling
28 replies to this topic
#21 Mpower29
Mpower29
  • Members
  • PipPipPip
  • 107 posts
  • Gender:Male
  • Interests:anything red!
    Farmall M & Farmall 460 Diesel
Posted 07 August 2013 - 06:29 PM
Got everything together tonight, still need some fine tuning tomorow and then i will post some pictures of what i did, not pulling again til the fifteenth so i wont know how everything worked until then.
#22 660 driver
660 driver
  • Members
  • PipPipPip
  • 6,746 posts
  • Gender:Male
  • Interests:Tractor pulling and workin on old binders. 660,F-20,30,14,12,W-30,460gas,1947 M,22-36,'53 Super M,IHC model "M" hit and miss,and allis chalmers c.
Posted 08 August 2013 - 06:39 PM
Its not nearly as big a problem at 3 miles an hour but I do get what your saying as far as keeping it straight down the track. I usually let the tractor almost find its own way as long as its not heading for an obvious bad spot. Tapping the brakes is a lst resort at the end of your pull.
Everybody bleeds red!
#23 CardaleBob
CardaleBob
  • Members
  • PipPipPip
  • 386 posts
  • Interests:Preserving old Equipment.
Posted 08 August 2013 - 07:16 PM
Hi:  I am not a tractor pulling expert, but I do know a bit of basic physics.  The point of your pulling pin gives the height from the ground, and the distance from the centre of the rear axle.  It does not matter how you get to this hitch point.  For example, if you weld the swinging drawbar solidly to the "hoop" drawbar, and then remove the front pivot pin from the swinging drawbar, will the tractor pull any differently?  CardaleBob.
10-20, 22-36, W40, WD40, TD35, Farmall"H", WD9, TD6, Rumely "16-30", JD"H", JD"AR", JD"A", JD"D", JD"R", Oliver "Super 88", Oliver "99", Case "500 Diesel", MH "Model 25", CAT "D814A", CAT "TWENTY", English Fordson "N", Fordson "E27N Gas", Fordson "E27N Perkins ", Numerous IHC Type "M" and other makes of engines.
#24 dmulhall
dmulhall
    Member
  • Members
  • PipPip
  • 10 posts
Posted 22 August 2013 - 02:58 PM
depends how long the chain is on the sled...
slightly better angle to get better traction at the rear tires...more weight on the back tires
#25 dmulhall
dmulhall
    Member
  • Members
  • PipPip
  • 10 posts
Posted 22 August 2013 - 03:05 PM
I know it doesnt make sense....but pull both ways and you can feel the difference
#26 M Diesel
M Diesel
  • Members
  • PipPipPip
  • 8,630 posts
  • Gender:Male
Posted 22 August 2013 - 03:49 PM
I was thinking that at first, but technically they are not the same. Since the bar can slide on the hoop, it does exert some pull from the forward attachment point. The geometry gets a bit complicated.
Gary M
1951 M -- 1951 MD
1953 Super C -- 1957 Farmall 450
1953 TD9 "Ichabod JR" aka "Icky"
1949 TD18 "Brutus" -- 1956 TD18-182 "Yard Dog"
1964 Loadstar 1600 -- 1975 Loadstar 1700 dump truck
1949 Massey 44
#27 660 driver
660 driver
  • Members
  • PipPipPip
  • 6,746 posts
  • Gender:Male
Posted 22 August 2013 - 05:48 PM
I have pulled probably 10 different sleds of all different styles and cardale you are right about using the swinging drawbar and removing the pin at the pivot point under the belly of the tractor....same concept as our pulling hitch. I have had good results on ALL of the sleds I have pulled using this pulling hitch we made. To me it is the cheapest easiest way to be successful on a Farmstock tractor! Keeps the tractor almost 100% stock hitch wise.
#28 Scott!
Scott!
  • Members
  • PipPipPip
  • 1,274 posts
  • Gender:Male
Posted 22 August 2013 - 06:14 PM
What if you bolted it solid so it didn't move?  (or if you use it like 99% of us and lock it in place with a couple bolts)
'49 Farmall MD
'54 Farmall SMTA
'43 Farmall H
'51 McCormick WD-9
#29 660 driver
660 driver
  • Members
  • PipPipPip
  • 6,746 posts
  • Gender:Male
Posted 22 August 2013 - 07:06 PM
It should be the same....haven't tried that yet but as long as it's not pulling from the belly of the tractor it should have the same affect.
Reply to this topic
