686-D-310 Injection pump diagram/parts(Leaking fuel from rear of pump)
Simple seal replacement?
8 replies to this topic
#1 bredred
bredred
  • Members
  • PipPipPip
  • 112 posts
  • Gender:Male
Posted 30 May 2013 - 09:01 PM
Just bought a 686 with the 310 german in it that needs a few things. It has a fuel leak from the rear of the pump. Right in the center of the rear where the injector supply lines come out of there is  what appears to be a hex head bolt protruding from the pump. It is leaking from this bolt/seal/oring. What exactly is behind the bolt? Is there a seal or o-ring that I can replace? Don't want to start taking things apart without knowing what all's going on. If I have to remove the pump does it need to be timed before removing it? If so, where can I find a good writeup on removing the pump? I have an old cheap shop manual but it doesn't say a whole lot. Was hoping maybe I could fix the leak with the pump on the tractor and not have to take it to a pump shop and have it rebuilt. The tractor starts and runs great by the way. Thanks!
74' 966 IH M&W turbo; 67' 706 Farmall C-291; 80' 686 IH D-310; 03' C80 McCormick; 400 Farmall gas; 2- 140 IH's; 495 CaseIH; 885 CaseIH,
Past Tractors: 574 IH diesel
#2 Dirtboyz07
Dirtboyz07
  • Members
  • PipPipPip
  • 4,066 posts
  • Gender:Male
  • Interests:5388 (replica prototype) from 1984 , 1976 1086 (first built)1975 1566 cab (all original) 1974 1566 open station,( improved farm, pulling tractor) 1971 1066 narrow front open station,1970 1456 gold demo.1970 1456 narrow front,1984 1420 Combine 1981 782 Cub Cadet 2005 DX24 Case International Compact Tractor
Posted 31 May 2013 - 05:28 AM
Yes it can be replaced , Injecpumped ( Ed ) on here works at a fuel shop, I am sure he has the part or I can help you out too.
Danny
1984 Prototype 5388,1976 first built 1086 sn #8601 ,1971 1066 narrow front ,1984 3088 open station , Prototype 1206 sn#508, Super WD 9 Pro Farm pulling tractor , Steiger 9150 , IH 782 Cub Cadet , 1984 1420 combine , Load cell tractors from Hinsdale IH engineering TX148 sn 505 and 501 , experiential 884 XL mfd , experiential 784 mfd .
#3 Injpumped
Injpumped
  • Members
  • PipPipPip
  • 644 posts
  • Gender:Male
  • Interests:motorsports, mostly tractor pulling, and drag racing. Now owner of Guenther Heritage Diesel, specializing in fuel injection systems on heritage era tractors.
Posted 31 May 2013 - 08:49 PM
Thanks Danny, I now actually own my own fuel pump shop now. I am thinking the VA pump just has a bleeder bolt in the center that seals on a taper, no seals or gasket. I could be remembering the wrong model VA though, been a while since I've worked on one.
#4 bredred
bredred
  • Members
  • PipPipPip
  • 112 posts
  • Gender:Male
Posted 31 May 2013 - 09:20 PM
Injpumped, so I probably need to just try tightening it up or putting some sort of sealant on it then? Thread tape isn't made for fuel....what about the liquid teflon sealant?
#5 Beans71086
Beans71086
  • Members
  • PipPipPip
  • 84 posts
  • Gender:Male
Posted 31 May 2013 - 09:44 PM
Here is some fuel rated stuff if that'll help ya.
http://cleanfit.com/...ape_70885.shtml
NF 706 German, WF 706 German, IH 1066, David Brown 990, Oliver Super 88 dsl
#6 jm1456
jm1456
    Member
  • Members
  • PipPip
  • 20 posts
Posted 01 June 2013 - 04:44 AM
that bolt uses a soft steel seal,part number 3132407r1 about 5 dollars according to parts book it says o ring but is not had to do the same on my va pump
#7 Injpumped
Injpumped
  • Members
  • PipPipPip
  • 644 posts
  • Gender:Male
Posted 01 June 2013 - 08:11 AM
JM, is right, there is a soft metal crush washer on some of those. You could try taking it out, look washer over good, and try reinstalling it if it looks ok. otherwise, it is an available item. That is simply a bleed screw back there, so nothing will fly out at you when you take it out. lol!
#8 bredred
bredred
  • Members
  • PipPipPip
  • 112 posts
  • Gender:Male
Posted 01 June 2013 - 09:16 PM
Thanks guys, I went and picked up the crush washer today along with some tie rod ends. Somebody had put a copper sealing washer on it instead of a crush washer so I guess that was the probem although I haven't put it back in yet. Thanks!
#9 Injpumped
Injpumped
  • Members
  • PipPipPip
  • 644 posts
  • Gender:Male
Posted 02 June 2013 - 08:35 AM
thats good to see. The copper probably wont take injection pressure that that bolt is subjected to. VE pumps, similar to VA do use a copper washer, but it's counterbored for blowout protection. The right washer on there will seal it up. Great News!
Reply to this topic
