does anyone use a stave silo for shelled corn
11 replies to this topic
#1 ihred
ihred
  • Members
  • PipPipPip
  • 186 posts
Posted 09 August 2005 - 06:30 AM
I am thinking about sticking an auger through a lower door and start filling it. i don't know if i would need to fill it but i need someplace to dump when the elevators are closed or lined up for six hrs to dump. two truckloads a day sure makes harvest drag on. if someone has done this did you use an ensilage blower? how much damage did you get? i'm feeding some cattle so i figured i'd screen it as i loaded out and use the screenings for feed. What do ya think, is it doable?
#2 MOChad
MOChad
  • Members
  • PipPipPip
  • 6,190 posts
Posted 09 August 2005 - 06:32 AM
neighbors put about 15,000 bu of beans in a stave silo last year. Just make sure you have some constant aeration if you leave them in there for any length of time. They filled with an auger through the top(it was a rather small one)
Chads
Present CaseIH 7140, 7120, 5240, 5140, IH 5488, IH 1466, 966. 1480
Family IH's past M, 400x2, 450, 460x2, 706G, 856, 1256, 966, 1086, 895CIH
Too bad Ignorance isn't painful!
#3 no_brainer
no_brainer
  • Members
  • PipPipPip
  • 6,881 posts
  • Interests:Any thing with a seat and engine any color will work and my classic XL with a C-15 kitty
Posted 09 August 2005 - 07:09 AM
Prairie farmer had a story about using silo's to store corn in it may have been high moisture corn though .
Dear Lord ,please protect me from all of your followers .
AND IF IT RUNS LIKE A DEERE ,THEN IT SMELLS LIKE A JOHN
I WILL STILL DUCK HUNT UNTIL OBAMAS JACK BOOTED THUGS ( UN TROOPS) BREAK INTO MY HOME AND STEAL MY GUNS
Sign up to be an organ donar as well
#4 IH RD
IH RD
  • Members
  • PipPipPip
  • 1,156 posts
  • Interests:Engines, Payline division, ag equipment, Steiger tractors, Big equipment in general
Posted 09 August 2005 - 07:47 AM
Hi ihred,
Make sure it has enough hoops on it for grain storage, back in the '80s, when there was the "gov. reserve program", everything was getting filled here. There was a guy that filled his stave silo and when it was almost full the silo exploded! Luckly no one got hurt. The density of grain is a lot more than silage per foot. After that mishap, people added extra hoops if they were going to store grain.
Be careful :) !
IH RD
Tractors: Steiger's ST-470, 330, 9330, 9130. 1586, 7110, 1206, 806, H-70D, 600D, SWD-9, M, H, W-4 & DX-26.
Combines: 2388 & 1480 .
Construction: TD-25E, a few TD-25B's, TD15C, 225 Cat excavator, Case 580 backhoe.
.....and many IH RD pumps (parts & complete).
#5 ChrisNY
ChrisNY
  • Members
  • PipPipPip
  • 4,558 posts
Posted 09 August 2005 - 08:18 AM
Like IH RD said be careful, neighbor had a stave silo tip over last year when he was filling it with rolled shelled corn, the density and weight is considerably greater than silage. That being said, it can be done, we used to fill a concrete silo every year with dryed corn, we did use a NH blower and there was some cracking and damage to the corn. I have heard you can use a grain vac and blow it up the pipe that way but have never seen it done but might be worth looking in to. Just be very careful.
1966 1206 S/N# 8926
1970 1456 S/N# 13146
1977 4386 S/N#1053
1961 460U S/N#10646
1984 IH 1460 Combine
Cub Cadet 129
#6 ihred
ihred
  • Members
  • PipPipPip
  • 186 posts
Posted 09 August 2005 - 08:55 AM
Some very good points made by everyone, and that was my main concern. will the bands hold the extra pressure. I found a good article on this subject and if i interpreted it correctly i should be able to fill to about 75 percent capacity safely. that would be 7500 bu if my calculations are correct. 16'x65' will hold 10,496 bu.
they also had a good idea to fill it using a blower to minimize kernal damage. here's the website if anyone is interested http://www.bae.umn.e...towersilos.html
#7 weedsabate
weedsabate
  • Members
  • PipPipPip
  • 196 posts
Posted 09 August 2005 - 10:05 AM
From the article, it would appear that you reall need to take great care in unloading the silo. Filling is kind of self explanitory, how fast, and how much grain damage you can tollorate. In determining what method you use.
Be Safe, Jerry
#8 Farmall Teen
Farmall Teen
  • Members
  • PipPipPip
  • 437 posts
  • Interests:-Like to drive tractors<br />-Staying off my a$$ and doing something
Posted 09 August 2005 - 11:34 AM
If the unloader works, then you don't need to have that auger at the bottom. But you can put corn in a Stave silo. That's what we put our high moisture corn in. We put dry corn in a bin.
Farmall Teen
Farmall Teen
"No farmers, no food"
"Money talks, bull sh*t walks"
"IMMIGRANTS MUST ADAPT, NOT AMERICANS
"If it ain't hard, it ain't worth a sh*t"
"It's better to be hated for you are than be loved for who you not"- Van Zant
"You've got to stand for somethin, of you'll fall for everthing"
#9 boog
boog
  • Members
  • PipPipPip
  • 7,653 posts
  • Interests:boogville , the BS capital of the world
Posted 09 August 2005 - 01:39 PM
<{POST_SNAPBACK}>
Neighbors have a metal silo they fill with corn. It did have a vertical auger up the side but it was slow so they replaced it with a grain vac. You know when they are filling the silo cause you can here the vac screaming even though they are almost a mile away.
IH tractors currently owned: '49 M, '52 SM, '53 stage 1 SM,  '53 stage 2 L-SM,  '54 SMTA, '66 806D w 2355 loader, co-own a '66 1206 with IHboog, store a '66 706 German for IHboog. IH / CIH equipmemt - ''13 Maxxum 115, 11 MX 275, '10 STX 435, '03 MX255, '14 7230 combine w/ 40' 2162 draper & 4412 ch,  '07 3310 sprayer,  '12 1250 16x30" planter, 12/23 1200 planter, 34' 330 True Tandem , 18' 870 , 7x16" 720 on-land plow, 6x18" 720 in-furrow plow, , #60 4X16" Plow, #1300 3 pt 9' sickle bar mower
#10 MOChad
MOChad
  • Members
  • PipPipPip
  • 6,190 posts
Posted 09 August 2005 - 02:12 PM
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Gentleman Dad bought his farm from had a 6" verticle "leg auger". Talk about slow, slow, slow.
Chads
Reply to this topic
