Best MCV pump to buy
3 replies to this topic
#1 gary1466
gary1466
  • Members
  • PipPipPip
  • 81 posts
Posted 12 November 2012 - 10:40 AM
I am working ona 1066 for a guy at work it needs a new mcv pump it won't prime when its cold. I worked at a IH dealer for 10 years till it closed in 1985 then had my shop for 10 years before going to a maintenance job in a factory for the benifits. When i ran my shop full time there were some pumps that weren't worth buying. I used some Case IIH pumps buy I was quoted over $500 for one now
#2 Sparky
Sparky
  • Members
  • PipPipPip
  • 2,627 posts
Posted 12 November 2012 - 11:10 AM
Hy-Capacity.
Travis
'74 966, '46 H, Two 990 mower conditioners, #15 rake and a #35 behind it, 241 bigroll baler, 560 plow, #37 disc, 19' 45 F.C. and a couple other off breeds. Got a 782 Cub Cadet, also. Not much else, but it keeps me out of trouble!
Money is NOT the root of all Evil, Lack of money is the root of all Evil...
#3 oneharvester
oneharvester
  • Members
  • PipPipPip
  • 517 posts
Posted 12 November 2012 - 08:20 PM
hy-cap in mine
long live red
#4 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,628 posts
Posted 12 November 2012 - 09:18 PM
I have been using HyCaps 1086 MCV pump (120114HD new) in all of the TAs I do. This is a 13gpm pump instead of the 9gpm that is stock, theory being that as these 40 year old tractors wear there is quite a bit of bypass oil in the steering,brakes etc. .The pump should list for about $300 from your local HyCap dealer. I also reman the MCV valve with 1566 springs to up the pressures some. I have never had a MCV pump failure.
"Rooster" 1066 puller tractor,
 "Banty" 666 7000# Puller toy, 312 3-LM Has stuff done to it.
"Emmy Lou" 1939 M , 1939 Farmall H (to be named later)
'  F-1206, 2WD 5088  1066 to be restored
2 782 Cadets 1 repowered. CanAm OutlanderMax650
 Dodge Cummins truck 2013"Buckweet"yes its automatic transmission
[i][color=#FF0000]
Can am outlander Max, XT Honda ST 1100
Torchmate CNC Plasma cutting table
