S-Series DT466 Purchase Advice
4 replies to this topic
#1 CactusWest
CactusWest
  • Members
  • PipPipPip
  • 178 posts
  • Gender:Male
Posted 04 August 2012 - 02:57 PM
I am looking to purchasing a 1980's series S-Series DT466 w/5 speed and two speed axle electric shift/less than 90K original miles/dump box.
Would appreciate feedback on things I should be looking for relative to the transmission and electric shift/and or engine. Truck is less than 26,000 GVWR.
I am looking for an S-series to restore and for light use.
Thanks
#2 dale560
dale560
  • Members
  • PipPipPip
  • 937 posts
Posted 15 August 2012 - 10:49 PM
we have an 1850 466 with a 5 and 2 with a grain box . we like it but a 13 speed would be better.
#3 Butch-Ky
Butch-Ky
  • Members
  • PipPipPip
  • 436 posts
  • Interests:tractor pulling,old tractors,hit an miss engins,farming
Posted 16 August 2012 - 12:51 PM
Would be a good setup What type of brakes?
#4 Delta Dirt
Delta Dirt
  • Members
  • PipPipPip
  • 1,583 posts
Posted 18 August 2012 - 06:06 PM
Two speed elec shift should be pretty straight forward----have had to replace shift motor; but if not shifting its most likely fuse or dirty switches.
For testing----you should be able to hear it shifting at the rear axle with ignition on and engine not running.
I am a fan of the two speed axles in this size truck.
Big item to look at is condition of tires-----they have skyrocketed lately
HP rating on DT---466 will be on configuration sticker on top of valve cover. Have looked at several-----but ended up with a pretty clean old F700 w/ 429 factory propane. It will probably haul me on home!!!!
Good luck
Delta Dirt
Avon, Ms. 38723
#5 Lars(wisc.)
Lars(wisc.)
  • Members
  • PipPipPip
  • 52 posts
Posted 20 August 2012 - 07:39 AM
Back in the day, I owned a 80's S series 2155 that was a single axle tractor and I removed the fifth wheel, lenghtened the frame and installed a 1800 gal Brownie fuel tank for delivering fuel. The trans was a Fuller Roadranger 10-speed, series 'A' 466. At about 400,000 miles the motor spun a bearing and at that time it was quicker to do a complete 'slide-out'. The local IH truck dealer said they had never seen a series 'A' with that many miles, claimed 200,000 miles was tops for those. Motor was replaced with a series 'B' 466, as the 'A' series blocks were no longer available.
Reply to this topic
