Head won't separate from block
#1
Posted 18 July 2012 - 12:07 AM
I've tried lubricants down the stud holes, I've tried putting the headbolt nuts back on and hitting them with a hammer to get them unstuck, and I've tried hitting it loose with a sledge hammer on a 2x4. It won't move!
If anyone has any ideas I could sure use the help.
#3
Posted 18 July 2012 - 11:53 AM
I had a friend of Dads bust my Honda 305 transmission doing that. Gotta make sure ALL the bolts are out.
1951 Farmall MD "Doc" -- 1953 Super C "Clyde" -- 1957 Farmall 450
1953 TD9 "Ichabod JR" aka "Icky"
1949 TD18 "Brutus" -- 1954 TD18A "Hoover" -- 1956 TD18-182 "Yard Dog"
1964 Loadstar 1600 -- 1975 Loadstar 1700 dump truck
1949 Massey 44
#4
Posted 18 July 2012 - 03:49 PM
Oh, and the air pressure in the cylinders as well can't hurt. Though is only about 900 pounds of force per cylinder.
Another avenue might be a puller of sorts. Set a board or plate across the studs for a jack to sit on, put a bar/brace across the jack and connect to the manifolds. Better yet, I would make a plate for the manifold studs so the pull is completely sheer for those bolts.
#5
Posted 18 July 2012 - 05:35 PM
I would not try accetelene but it sure worked good that time
#7
Posted 19 July 2012 - 02:19 PM
OMG! Good thing you DID stand back! That wudda won on Funniest Videos.when i was a kid my dad had a irrigation well drilled and the welder man out working on the rig had a wisconsin engine that he flooded and dad said to take the plugs out and light a match at the plug holes and he said no he would put some accetelene in the carb and he did and dad had grandpa, hired man and i stand back and he cranked it over about 2 turns and it blew the head, carbuetor and intake off and it went over the fence and landed in the water at the lake about 100 ft away. he waded out and got the parts and threw it in the back of the truck and went to town.
#8
Posted 20 July 2012 - 12:18 PM
Its a quick and easy way to produce tons of even push force without having any sudden explosion or outburst like air does.
"Save America, money, and fuel by burning bureaucrats!"
Other forums you can find me at. http://www.electro-tech-online.com/ and http://cr4.globalspec.com/ .
#9
Posted 21 July 2012 - 08:47 PM
#10
Posted 23 July 2012 - 12:34 PM
I've had those two studs seize in the head before. If you look on the cnh parts website, it shows the two sleeves, p/n 351972R1.
Reply to this topic
Also tagged with one or more of these keywords: W-4, engine block, head, stuck, cylinder head
Boards →
Coffee Shop →
IH 100 Press Drill - Are they any good?Started by Roschro , 02 May 2013 |
Boards →
General IH →
d282/d301 interchangeStarted by 234-IA , 07 Nov 2012 |
Boards →
IH Engines →
farmall 300 pistons in a W-4 is it possibleStarted by 1950McCormickW-4 , 05 Nov 2012 |
Boards →
General IH →
IH 141 combine motor stuckStarted by corknutz , 22 Aug 2012 |
Boards →
IH Engines →
W4 with dry wrist pinsStarted by Roschro , 31 Jul 2012 |
