international 403 combine
combine
12 replies to this topic
#1 dieselmech
dieselmech
    Member
  • Members
  • PipPip
  • 11 posts
Posted 25 May 2012 - 09:16 AM
what are good bad ugly about this what kinda heads can you run with these kinda interested in one
52 Farmall Super M
55 International 400
63 Farmall 560 Diesel
69 Farmall 756 Diesel
412 Fast hich plow
#2 615 spike
615 spike
  • Members
  • PipPipPip
  • 75 posts
Posted 25 May 2012 - 06:54 PM
think of them as a 715 with a little smaller engine C263 vs C301 in gas. Cylinders, concaves, cleaning screens all about the same. Cylinder speed changed by swapping sprokets. Heads originally attached at the front of the cylinder as they had their own feeder houses. 13 and 15 foot were the most common around here. some were equipped with heiniker or hart-carter floating bars..Corn heads 3 row and 4 row newest you could use was a 743, the bane of my existance when it came time to repair. Kits were available to mount a feeder house that fit 715's . That allowed the use of 800 series corn heads and 810 grain heads. Parts may be a problem. There is some interchange with 715's which is why i still have two of them in my salvage collection. Most of them were long ago scrapped out, they weigh about five ton. If they havn't been stored cleaned and inside it is likely the bottom of the bin and the shaker pan under the cylinder will be rusted out in spots. cb
#3 hagan
hagan
  • Members
  • PipPipPip
  • 2,095 posts
Posted 25 May 2012 - 07:48 PM
simpler than a 715 and easier to set. ran a 403 hydro from 67 to 82 then traded it for a 715 diesel. gained more hp larger grain tank, easier air adjustment and learned how to replace straw walkers as the 715 was hard on walkers. I had put the fan kit in both of them from Ray Stickle the combine man from Idaho and it made a big difference in the way they cleaned grain. Chances are the concave is needing reprs and st john does that but when there look at the grain pan. a heck of a job they come out the front.
My 403 was a gas hydro with 16ft header and 715 was a diesel hydro with a 17.5 ft header. now run a 1440 with the 17.5 ft header
#4 615 spike
615 spike
  • Members
  • PipPipPip
  • 75 posts
Posted 26 May 2012 - 06:45 AM
Hagan is right about the grain pan if you actually pull it out. Did that once for a 303, once was enough. My current solution is to use a section of another pan in good shape. Clean and coat old pan with silicone calk , bedliner, contact cement , or whatever you have on hand to make the pieces stick together. place patch on old pan and secure using self drilling self tapping screws.Caulk edges and you're good to go.
#5 hagan
hagan
  • Members
  • PipPipPip
  • 2,095 posts
Posted 26 May 2012 - 01:55 PM
make sure the seal at the front of the grainpan is good if you patch it up
#6 706wheatland
706wheatland
  • Members
  • PipPipPip
  • 127 posts
Posted 26 May 2012 - 03:11 PM
I would think it will hard to find parts unless you can get a parts combine to keep her going. I never liked the idea of changing heads with a feeder house attached. I've got an early 715 gas C&S special and have a little trouble finding a few things. Good luck
#7 dieselmech
dieselmech
    Member
  • Members
  • PipPip
  • 11 posts
Posted 31 May 2012 - 05:38 PM
thanks for the comments its alittle further than i want to travel to get it the guy has three of them so would be able to get parts machine but thinking im going to pass on them and keep looking. idealy would like to find a simlar combine in northern illinois
52 Farmall Super M
412 Fast hich plow
#8 Sean in NE
Sean in NE
  • Members
  • PipPipPip
  • 609 posts
Posted 31 May 2012 - 07:07 PM
I seen this post, and thought I'd share some photos of my family with their 403 combine. Sorry I can't be of any help on the actual machine thou.
My YouTube channel: http://m.youtube.com...8?feature=guide
Tractors of the farm:
1997 Case-IH 8940 FWA, 223hp
1996 Case-IH 7250 FWA, 250hp
1979 International 3588, 2+2 "Anteater" 150hp
1978 International 1086 2wd, 144hp
Trucks of the farm:
2007 International 9400, ISX 475hp, 13spd
1998 International 9300, 3406E 455hp, 18spd
1975 International 200, 4x4, 345 automatic
1974 International 1700, 392IC, 5spd
#9 Sean in NE
Sean in NE
  • Members
  • PipPipPip
  • 609 posts
Posted 31 May 2012 - 07:08 PM
And another.
Trucks of the farm:
#10 Sean in NE
Sean in NE
  • Members
  • PipPipPip
  • 609 posts
And the last one.
Trucks of the farm:
