Need more help on my 1066
noticed a little water in oil
6 replies to this topic
#1 JandM966
JandM966
  • Members
  • PipPipPip
  • 1,470 posts
Posted 22 March 2012 - 03:38 PM
Ok, well Ive been stewing over this for a day or two now, and its about to drive me up a wall. I purchased a DT466 to replace the 414 in my 1066, I finally got it in there, but I left the tac cable off the tac drive, since the tractor is stripped down for paint. When I got the engine in the tractor, I changed the oil, and then took it down the road to the wash bay. Got over there and spent two hours washing on it, and thought I would check the oil, and it had water in it. The level never came up, but it was enough to turn the new oil gray. The old oil never had a trace of water in it. The only thing I did to this engine was change front covers, so Im leaning towards one of two possibilities.
A)The water entered the oil pan through the open tac drive as I was washing it. I did spend alot of time washing on the front of the engine, before I realized what I was doing.
Or
b)I screwed up the new front cover gasket when I put it on, which I find very unlikely.
Im really hoping its a, but I dont know how much water it would take to turn the oil from a clearish brown, to a gray color? But then again I did spend the biggest part of my two hours on the front of the engine, with a pressure washer. Maybe Im over reacting, but I just want this done. It seems like every time I finish one thing on it, ten more problems show up.
What do yall think is the most logical reason to this??
John
Proud member of DILLIGAF pullers assoc.!
If we give up our right to freedom for security, in the end we have niether. (I think its from an NRA bumper sticker)
If its green you either mow it or spend it!
If it aint red leave it in the shed!
"God bless America and the farmer that feeds your fat a$$!" have that on a bumper sticker
Blowing smoke til Im broke, running red til Im dead.
1943 Farmall B,1964 IH 706(future puller), 1974 IH 966 openstation with a Buhler-Allied 795 loader, 1974 IH 1066 with DT466 and 3LM turbo, 1979 IH 1586, 1991 CaseIH 5140 with westendorf WL-42 loader, IH 510 4 bottom plow (BIL's uncle bought it new and only plowed 20 acers and sat in a shed til i bought it!) John Deere 735 MowCo, Hesston 3940 12 wheel hi-capacity wheel rake, 2012 John Deere 468 with netwrap , 1999.5 Ford F-250 XLT extended cab powerstroke diesel!!
Other colors: '68 JD 2510.
Past tractors:'74 IH 1466 Factory Fender tractor, '84 IH 3688, '74 IH 1466 with Cab, '79 IH 1086 with cab, '78 AC 7060 with cab, '65 AC 190xt, '64 Oliver 1800C, '64 Oliver 1600, '60 Oliver 1900, '63 JD 4010, '92 JD 2555 with cab, '64 JD 3020.
#2 Rick G.
Rick G.
  • Members
  • PipPipPip
  • 4,450 posts
Posted 22 March 2012 - 03:49 PM
John,
What if you change the engine oil and filters, then just monitor the situation to see if it quickly re-occurs. If not fine. If it does, you'll know it wasn't the power washing and will have to start a deeper investigation.
Rick G.
Tractor owned: 1976 IH 1466 Black Stripe, Serial # 30313
#3 Owen Aaland
Owen Aaland
  • Members
  • PipPipPip
  • 2,617 posts
Posted 22 March 2012 - 03:54 PM
Do you have antifreeze in the cooling system? Crack the oil drain plug loose and see it you get water or antifreeze.
#4 JandM966
JandM966
  • Members
  • PipPipPip
  • 1,470 posts
Posted 22 March 2012 - 04:15 PM
No, I just put straight water in it temporary. This engine came out of a 3788 which had the electrical temp sender, so I opted to leave it in there until after I got it painted and then put my mechanical sender in it, so I didnt want to fill it with high dollar antifreeze and then have to drain it right back out.
John
#5 JandM966
JandM966
  • Members
  • PipPipPip
  • 1,470 posts
Posted 22 March 2012 - 04:16 PM
John,
Rick G.
Rick, I thought about that but Im going to go ahead and paint this tractor while I have it tore apart so I dont want to have it all painted and then find out Ive got to pull it all apart again for this. Im kinda trying to knip it in the bud if you will...
John
#6 international3088MFD
  • Members
  • PipPipPip
  • 1,150 posts
Posted 22 March 2012 - 05:33 PM
I'd spring for option A.
dad did a similar thing with the skid loader this spring. had a oil leak, washed the engine with hot water, come to find out a plug came out the top of the oil pan, check oil. and sure enough water in the oil.
so drop the oil, fill with fresh and see if it changes.
WEGMAN FARMS: 325 acres of corn, beans, oats and alfalfa crop rotation.
80 cow Holstein milking operation.
Tractors on the Farm: Case IH MX Magnum 200, MX Magnum 180, McCormick MTX 135, Case IH MX 110, IH 686 D312 diesel, Farmall DX55, Farmall Super M, stage II, Case 650 dozer. Case IH 2144 combine. Run Red
My Tractors: 1972 IH 1066, 1957 Farmall 350, 1950 Farmall H, Cub Cadet 100, Cub Cadet 682. Cub Cadet 149, 1951 Massey Harris 44, 350 V-8 conversion tractor.
SEARCHING FOR: International 966 Diesel. Serial number: 29192
Gone but not forgotten: International 3088 open station w/ Elwood MFD
#7 pullinfarmer
pullinfarmer
  • Members
  • PipPipPip
  • 151 posts
Posted 22 March 2012 - 06:37 PM
Drain the oil over night , then get ahold of a coolant pressure tester, pump it up and see if it leaks water , if so drop pan and see from where , if not try oil/filters and run it
