856 Farmall speed transmission countershaft
#1
Posted 14 March 2012 - 03:23 PM
I've been fixing these IH's since 1979, at IH dealers for 17 years and my own shop since 1996.
#2
Posted 14 March 2012 - 03:32 PM
#3
Posted 14 March 2012 - 03:44 PM
I always sell or use a new, wider countershaft nut if the original was a thin nut. Torque it to 300 ft.lbs, then bend over the tab washer in at least two places. We put grease on the washer, so the nut doesn't try & stick to the tab washer when torquing it. Otherwise, it likes to spin the tab washer, tear off the lil tab, and not hold the nut tight at all.
"Think Outside The Bun!" - Taco Bell
"Oh, you hate your job, oh my god, why didn't you say so? Ya know, there's a support group for that, it's called Everybody! They meet at the bar!" Drew Carey
TEAM 407: "We don't care about your intake manifold part number!"
Link to my Facebook album of the 1206 puller project
#4
Posted 14 March 2012 - 06:17 PM
The 06 thru 66 series books list the lower torque for the nut because the countershaft nut was originally a thinner nut. The ones in an 86 series were thicker, catching more threads on the countershaft, and could take a greater torque.
The early countershafts didn't have enough threads for full engagement of the thick nut.
"Yet people are considered to be "educated" after they have spent so many years in ivy-covered buildings, absorbing the preconceptions that prevail there."
Thomas Sowell
Being happy doesn't mean everything is perfect. It means you've decided to see beyond the imperfections.
#5
Posted 15 March 2012 - 01:29 AM
I would tighten that nut like Pete 23 advised; however I do pin them with an 1/8" roll pin. I take the nut into our machine shop and put it in a vise set at a 45 degree angle. I then drill the hole through one of the six corners of the nut; the hole will exit within the inside threads. With the nut drilled this way, use it as a guide to drill the shaft; wiring the pin is not necessary.
#6
Posted 15 March 2012 - 10:45 AM
Pete 23 nailed it as to why you never should torque that nut; you will have one unhappy customer when he picks up his tractor and complains about the gear noise.
And where exactly do you think the gears going to be besides the original spot?? If the countershaft is not properly tightened it allows the spacers to spin freely on the shaft, causing undue wear, and allows the gears to walk on the shaft. I torque every one to 300 lb/ft, bend a tab (unless on LH shafts) and pin it. I have always torqued them, and have never encountered a noisy transmission afterwards.
#7
Posted 15 March 2012 - 11:10 AM
Those gears fit loose on the splined shaft so when you tighten them up they **** off to the side. You suppose HY-Capacity says to back nut off because they might have got a lot of complaints about noisy transmission after some one installed their TA unit. No fear though, they will be loosen again soon as they wear in a while. And I have been putting TA's in since the first one went out of an 806 in about 1966. This is what is great about being in a free country. , Every one can do it the way they have confidence it will work for them. . Your not going to change your way because I say so, and I am not going to change my way because you say so.
#8
Posted 15 March 2012 - 03:16 PM
I hope I didn't start a controversy here!
To each his own, no right or wrong, just different.
#9
Posted 15 March 2012 - 05:20 PM
#10
Posted 15 March 2012 - 05:36 PM
