TD-14A Bottom Roller
Started by
Vic Bunn
, Mar 05 2012 06:23 PM
8 replies to this topic
#1
Posted 05 March 2012 - 06:23 PM
Can anyone tell me if a roller with 268306 R1 stamped on the track roller shaft bracket will work in position #1 on my TD-14A? It is single flange but looks more like the one on my TD-14. It was sent to me by mistake & was told to keep it. Now I need a #1 & a #2 roller. When I parked the tractor this morning both rollers were smoking & very hot! I knew something was wrong when I came up my driveway in 1st gear instead of the normal 3rd.
1939 Farmall A
1942 TD14
1943 Ford 9N
1953 TD14A
1999 Rhino 3526
1942 TD14
1943 Ford 9N
1953 TD14A
1999 Rhino 3526
#6
Posted 25 March 2012 - 09:37 PM
==============================================================================================================I just changed my mind. My crawler doesn't have 3/4" bolt holes! Now I need a single flange roller.
have a piece of pipe turned down on a lathe and insert them into the holes to get to the size you need for your 14 bolt hole. double flange rollers can be anywhere but at the back as the sprocket will hit it.
#9
Posted 26 March 2012 - 07:32 AM
The Captain is right. I put a double roller on the fornt and it sure helps the tack come off. If it were not for the worn out rock guard It would come right off. I plan to change the fornt roller to a single flange and weld a bunch of leaf spring to the rock guard to keep the track on. The fornt sprocket wiggles so I have a problem there also.
