466 injector pumps
putting 466 in our 1066
13 replies to this topic
#1 red farmer
red farmer
  • Members
  • PipPipPip
  • 906 posts
  • Gender:Male
Posted 05 February 2012 - 05:52 PM
we are putting a 466 in our 1066. we were told that we should get a 11mm head for our pump that it would give us some more hp. we still want to use the tractor on the farm as well as tractor pull with it and was told that would be good. was wondering what you guys thought about this and looking for some opinions. any ideas are appreciated!
my red tractors: c, h, super m, 1206, 826 gold demonstrator, 1026 gold demonstrator, 1086, 5488
782 &782d cub cadet
off breed: jd a
case ih 7500 5 bottom auto reset moldboard plow, 2 little genius 2 bottom plows
god bless america and the farmer that feeds your fat ass!
#2 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,449 posts
  • Gender:Male
  • Interests:Rebuilding IH farm tractors, Pulling RED tractors, Working in my shop. MOPAR cars. Austrailian Opals
Posted 05 February 2012 - 08:36 PM
The Mack 11mm pump is a good option if you are going to farm with it also. I assume you will use better injectors, you may consider lines also. Some of the AMBAC pumped truck 466s had larger lines, this is a inexpensive way for more HP. I assume that you will change the T-04 to a 3-LM??
If it was me I would find a 13mm AMBAC and use that just for pulling, simple to switch pumps for farming..
"Rooster" 1066 puller tractor, Soon to be turned back into a farm tractor
 "Banty" 666 7000# Puller toy, 312 3-LM Has stuff done to it.
"Emmy Lou" 1939 M , 1939 Farmall H (to be named later)
'  F-1206, 2WD 5088  1066 to be restored
2 782 Cadets 1 repowered. CanAm OutlanderMax650
2 Dodge Cummins trucks 2013"Buckweet" and 2004 "Duke"
[i][color=#FF0000]
Can am outlander Max, XT Honda ST 1100
Torchmate CNC Plasma cutting table
#3 IH5088MFD
IH5088MFD
  • Members
  • PipPipPip
  • 118 posts
  • Gender:Male
  • Interests:Repairing and rebuilding Red tractors, farming and tractor pulling and anything to do with IH
Posted 05 February 2012 - 08:45 PM
If you are wanting something that you can put in and leave on to farm with go with an 11mm, otherwise find a 13mm and switch pumps for pulling. I have set a couple 1066's up with 466's and 3lm-466 turbo, 5 hole injectors and 11mm head in the pump and they run pretty good depending on what class you are pulling in. They really amaze me how they run just running them everyday. The one I left set at about 210 HP and it didn't even smoke at all but the responsiveness of the tractor was awesome, compared to just turning up a 10mm to that horsepower. Thats just my 2 cents.
All the 5X88 series in 2 and 4 wheel drive. 1086 restored, 1066, 966, 7140, 9330, 756, 756 custom, 856, 1256, 1456 Gold Demo, 1026 Gold Demo, 826 gold demo, 1206, 706, I706, 350 utility diesel, 350 hi util. , 400, 450, 450LP, 560LP wheatland, 650LP, super mta, 52 and 54 sm, h, m, 1468, 400d #41457, 560, 660, 460, td6, t6, 786,1256 wheatland, W450 diesel, W450, Hydro 100, 2588 combine
#4 red farmer
red farmer
  • Members
  • PipPipPip
  • 906 posts
  • Gender:Male
Posted 05 February 2012 - 09:13 PM
we had a 3lm on the 414 and will put it on the 466. the 466 we have is out of a ih wheel loader from a neighbor. not sure what injectors are in it. have to pull them out and see what we have. the lines look bigger on the 466 than the 414. where is a good place to find a 11mm or 13mm? we pull in farm stock classes but most of the tractors run really good. we had the 414 putting out 250 hp with the stock pump turned all the way up and a 3lm on it.
782 &782d cub cadet
off breed: jd a
#5 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,449 posts
  • Gender:Male
Posted 05 February 2012 - 09:30 PM
Keep checking on the PullOff page, lots of listings as guys move up a class or two. There are some "Tricks" that can be done to the stock to maximise the fuel output..
[i][color=#FF0000]
#6 Dirtboyz07
Dirtboyz07
  • Members
  • PipPipPip
  • 3,849 posts
  • Gender:Male
  • Interests:5388 (replica prototype) from 1984 , 1976 1086 (first built)1975 1566 cab (all original) 1974 1566 open station,( improved farm, pulling tractor) 1971 1066 narrow front open station,1970 1456 gold demo.1970 1456 narrow front,1984 1420 Combine 1981 782 Cub Cadet 2005 DX24 Case International Compact Tractor
Posted 05 February 2012 - 10:36 PM
Your stock pump will put out about 280 hp , like Gonzo said there are some tricks you can do to that pump to get some more out of it. You could put a 13mm pump on .093 lines and big injectors then turn it down for farming or just put the stock one back on and leave the lines and injectors in if you want. Just don't buy a 13 mm pump and think this will work with the stock lines and injectors, it won't and it will seize the head in the pump.
You can pm me and I can help you out with timing and other things that go along with these set ups.
Danny
[size=2] '84 5388 (replica prototype), '05 International CXT (Former International Show Truck), '75 1566, '71 1066 (narrow front open station), '84 1420, '81 782 Cub Cadet[/size]
#7 red farmer
red farmer
  • Members
  • PipPipPip
  • 906 posts
  • Gender:Male
Posted 06 February 2012 - 07:29 PM
does the 13mm pump have decent longevity? i was told they have to be machined out correct?
782 &782d cub cadet
off breed: jd a
#8 Injpumped
Injpumped
  • Members
  • PipPipPip
  • 597 posts
  • Gender:Male
  • Interests:motorsports, mostly tractor pulling, and drag racing. Now owner of Guenther Heritage Diesel, specializing in fuel injection systems on heritage era tractors.
Posted 06 February 2012 - 08:31 PM
I can also set one up with a 13MM hydraulic head. The 13's are pretty reliable, the 15's tend to be fragile as glass. All are custom made.
#9 red farmer
red farmer
  • Members
  • PipPipPip
  • 906 posts
  • Gender:Male
Posted 10 February 2012 - 08:05 PM
thanks for the info guys! glad for all your input, no better place to find info for ih than here!!
782 &782d cub cadet
off breed: jd a
#10 JandM966
JandM966
  • Members
  • PipPipPip
  • 1,470 posts
  • Gender:Male
  • Interests:Tractor pulls, Spending time with the mrs. cologna...and FARMING!!!
Posted 10 February 2012 - 08:22 PM
I talked to local diesel shop about having a 13mm pump built. They said if I find the 13mm head they will put it together for 500 bucks. They said the only problem with going to a 13mm is possible siezure of the head. My idea was just like yours put on the 13 for pulling then putting the 10mm on for farming. I have a spare pump just need the parts to build it...
I ordered a new 3lm the other day picked it up today. Man it looks huge compared to the T04!!
John
Proud member of DILLIGAF pullers assoc.!
If we give up our right to freedom for security, in the end we have niether. (I think its from an NRA bumper sticker)
If its green you either mow it or spend it!
If it aint red leave it in the shed!
"God bless America and the farmer that feeds your fat a$$!" have that on a bumper sticker
Blowing smoke til Im broke, running red til Im dead.
1943 Farmall B,1964 IH 706(future puller), 1974 IH 966 openstation with a Buhler-Allied 795 loader, 1974 IH 1066 with DT466 and 3LM turbo, 1979 IH 1586, 1991 CaseIH 5140 with westendorf WL-42 loader, IH 510 4 bottom plow (BIL's uncle bought it new and only plowed 20 acers and sat in a shed til i bought it!) John Deere 735 MowCo, Hesston 3940 12 wheel hi-capacity wheel rake, 2012 John Deere 468 with netwrap , 1999.5 Ford F-250 XLT extended cab powerstroke diesel!!
Other colors: '68 JD 2510.
Past tractors:'74 IH 1466 Factory Fender tractor, '84 IH 3688, '74 IH 1466 with Cab, '79 IH 1086 with cab, '78 AC 7060 with cab, '65 AC 190xt, '64 Oliver 1800C, '64 Oliver 1600, '60 Oliver 1900, '63 JD 4010, '92 JD 2555 with cab, '64 JD 3020.
Reply to this topic
