7400 fuel supply problem
hard starting
20 replies to this topic
#11 ontsandfarmer
ontsandfarmer
  • Members
  • PipPipPip
  • 31 posts
Posted 10 March 2012 - 04:05 PM
check valve ? maybe 6 injectors?
#12 chip man
chip man
  • Members
  • PipPipPip
  • 565 posts
Posted 11 March 2012 - 01:51 AM
Check the glow plug relay. With a powerstroke engine, the voltage drops at least 3 volts, and if the relay is old the terminals inside get burnt amd the plugs dont heat enough to start it easily when its cold.
#13 Zac Weidner
Zac Weidner
  • Members
  • PipPipPip
  • 210 posts
Posted 11 March 2012 - 10:43 AM
Would this be the intake heater or does it have glow plugs also? The voltmeter on the dash shows a good 2V drop, but not 3 while operating.
#14 ontsandfarmer
ontsandfarmer
  • Members
  • PipPipPip
  • 31 posts
Posted 13 March 2012 - 06:35 PM
you have a DT466 correct? if so no glow plows you have a grid intake heater that thing should start right up even at 25 degree weather still sounds like a fuel problem . you need to hook it up to a lap top check your huei pressure needs min 300 psi to start .
#15 joshont
joshont
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 24 March 2012 - 08:05 PM
Could be a bad o-ring on an injector causing the fuel to leak off, could also be an injector, pretty safe bet to say you'll be pulling the injectors out and o-ringing them, these were bad for injectors and o-rings
#16 Zac Weidner
Zac Weidner
  • Members
  • PipPipPip
  • 210 posts
Posted 25 March 2012 - 08:44 AM
We have internal injectors with a common fuel rail, actuated by oil pressure. Would these O-rings still be applicable to this type of engine?
#17 joshont
joshont
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 28 March 2012 - 07:12 PM
Yes, these o rings are applicable to this eng.
#18 Zac Weidner
Zac Weidner
  • Members
  • PipPipPip
  • 210 posts
Posted 29 March 2012 - 04:37 PM
Okay, I will check into the O-rings issue. Thank you for the tip!
#19 Zac Weidner
Zac Weidner
  • Members
  • PipPipPip
  • 210 posts
Posted 04 April 2012 - 07:12 PM
Okay, we have a whole new animal with this problem now. The other day I was spreading a full load of urea on some pretty solid, flat bean stubble ground, and the truck lost power and almost died on me about 4 or 5 times within about 30 minutes or less. It also had a very hard time getting rolling from a stop with the bed pretty full. Once it got going, it seemed to run pretty well, except for the 4 or 5 times that it would all of a sudden just lose all power and come to a stop, idling at about 400 RPM with no ability to even accelerate with the transmission in neutral. The engine light would come on very often, even after I got some of the load spread.
Once the load got a bit lighter, the light would come on, but I could get it to go out for a minute or so by very quickly letting off the throttle, then to the floor. It definitely has a major problem, and I see it being one of those ghosts that sucks down a whole lot of money trying to chase it.
The next day I spread another load, half a load at one time, except it was on some hilly, freshly disked ground and the light didn't even come on. I would guess fuel pump, but it seems too inconsistent to be a pump. Could there be a computer going bad?
Any help is greatly appreciated.
Thank you,
Zac
#20 ontsandfarmer
ontsandfarmer
  • Members
  • PipPipPip
  • 31 posts
Posted 04 April 2012 - 07:27 PM
pull all 6 injectors only takes one to cause your problem if she don't start then sounds like huei pump gear loose on shaft.
