1000 cub cadet
#2
Posted 29 July 2011 - 08:33 PM
http://www.xtrememot...det_History.htm
'63 Cub Cadet Original, '64 100,'65 70, '66 71, '70 127, '75 1650
#3
Posted 30 July 2011 - 06:55 AM
The PTO was an elec clutch, similar in operation to a car's AC compressor clutch. They seem to be durable enough, but they turn on with a switch, so they're ON or OFF, you can't feather them into engagement.
They had a small bendix style starter, and the generator, actually was an alternator incorporated into the flywheel, they're more of a hassle to work on than the older style starter/generator which hung out in the open. But I don;t think they required as much repair as the S/G's did.
They're a solid tractor, other than the rubber engine mounts. Parts are readily available, but as Briguy says, they keep getting more expensive all the time.
#4
Posted 30 July 2011 - 07:08 AM
Another weak spot on the Quietline gear drives is the driving disc on the engine clutch, because the engine moves around on the rubber mounts the disc has to flex and they will eventually crack and require replacement. All the earlier GD clutch drivers were made from thcker steel and didn't flex/crack.
The nice thing about the 10hp in those is that they just don't shake that much (unlike my 1650 which is a vibrating s.o.b.). If the ISO mounts are shot I would consider just getting a set of solid mounts that the puller like to use. Like Dr. Evil said, if the rubber mounts go bad it can cause clutch problems, the solid mounts would help with that. I almost like the bendix starters, they crank the engine over faster and seem to start a little easier than the generator setup.
