1086 Shifter problems
9 replies to this topic
#1 Jason Epperson
Jason Epperson
  • Members
  • PipPipPip
  • 74 posts
Posted 19 May 2011 - 05:40 PM
My Dad was running my 1086 today drilling beans for me. I'm not sure what happened but I cant shift the range shifter. I have high only. When I go to others it acts like it is locked in two ranges. He said he got into low range once. Any ideas??
#2 Steve Bosshard
Steve Bosshard
  • Members
  • PipPipPip
  • 43 posts
  • Gender:Male
  • Interests:Amateur Radio (NU5D) - The Catholic faith.
Posted 19 May 2011 - 06:05 PM
Has happened to me a few times. The shift mechanism says you are out of gear but really are in gear. I remove the bolts from the seat platform and the floor board cover - remove the cover then (3 bolts behind the seat I believe) - Then wrestle the seat up and backwards so you can access to the shifter arms. You will find moving one of the arms gets it out of gear and all will be OK. You may need to adjust the arms to prevent future headaches. steve
"It is a poverty to decide that a child must die so that you may live as you wish." Mother Teresa
#3 Dirtboyz07
Dirtboyz07
  • Members
  • PipPipPip
  • 3,917 posts
  • Gender:Male
  • Interests:5388 (replica prototype) from 1984 , 1976 1086 (first built)1975 1566 cab (all original) 1974 1566 open station,( improved farm, pulling tractor) 1971 1066 narrow front open station,1970 1456 gold demo.1970 1456 narrow front,1984 1420 Combine 1981 782 Cub Cadet 2005 DX24 Case International Compact Tractor
Posted 19 May 2011 - 06:44 PM
There are two ways to get it out, shut it off on the level and get a big snap on pry bay, then you can go in the shift console and try and get it back in neutral . If you have no luck with this you can go under the cab from the hyd remote side and you can move the shift linkage back to neutral .
Good Luck, Danny
[size=2] '84 5388 (replica prototype), '05 International CXT (Former International Show Truck), '75 1566, '71 1066 (narrow front open station), '84 1420, '81 782 Cub Cadet[/size]
#4 bmacguyver
bmacguyver
  • Members
  • PipPipPip
  • 280 posts
  • Gender:Male
Posted 19 May 2011 - 07:42 PM
probly coming up on time to rebuild the shifter and maybe linkage.
hth
mac
#5 Matt Kirsch
Matt Kirsch
  • Members
  • PipPipPip
  • 1,824 posts
Posted 20 May 2011 - 11:18 AM
I've noticed when a tractor doesn't shift into gear smoothly and immediately, people tend to ram and jam harder and harder on the shift lever instead of trying to finesse it in by feathering the clutch pedal.
Your dad probably got a little rambunctious with the shifter because it wouldn't shift, and popped something out of place.
#6 88seriesrestorer
88seriesrestorer
  • Members
  • PipPipPip
  • 1,914 posts
  • Gender:Male
  • Interests:Anything to do with the 5x88's
Posted 20 May 2011 - 04:34 PM
It needs the shift kit put in it and while your there you might as well put the updated shifter rail in to and take a good look at the shift fork itself while you have it out.
Do not go adjusting the linkage. They don't just come out of adjustment there is a problem.
Visit my website: www.triplertractors.com
Send Me An Email : trick26@frontiernet.net or 618-795-3950
#7 BK1086
BK1086
  • Members
  • PipPipPip
  • 134 posts
  • Gender:Male
  • Interests:my kids, farming, old trucks, and tractor pullin
Posted 20 May 2011 - 04:48 PM
does it have to be a Snap-On pry bar? :P
BK1086
1981 1086, 1978 886, 1986 1660, 1966 806
#8 Jason Epperson
Jason Epperson
  • Members
  • PipPipPip
  • 74 posts
Posted 20 May 2011 - 05:45 PM
Thanks for the help!! I got it popped back into neutral and it's ok for now. Does the dealer have the updates for the shifter that was mentioned? I would like to put in different levers that don't get in the way also. Later 86 series had straighter ones right? What about aftermarket?
#9 Jason Epperson
Jason Epperson
  • Members
  • PipPipPip
  • 74 posts
Posted 22 May 2011 - 08:00 AM
Are there aftermarket shift levers available for this tractor?
#10 JandM966
JandM966
  • Members
  • PipPipPip
  • 1,470 posts
  • Gender:Male
  • Interests:Tractor pulls, Spending time with the mrs. cologna...and FARMING!!!
Posted 22 May 2011 - 08:16 AM
Yes there are. I believe HY-Capcity has some. The later 86's had ones the curved back toward the rear of the tractor...instead of them coming straight out of the console they would come out and curve up. It made getting in and out of the tractor alot easier!! I put these on my old 1086 along with a door shock and it was a dream crawling in and out of it them.
John
Proud member of DILLIGAF pullers assoc.!
If we give up our right to freedom for security, in the end we have niether. (I think its from an NRA bumper sticker)
If its green you either mow it or spend it!
If it aint red leave it in the shed!
"God bless America and the farmer that feeds your fat a$$!" have that on a bumper sticker
Blowing smoke til Im broke, running red til Im dead.
1943 Farmall B,1964 IH 706(future puller), 1974 IH 966 openstation with a Buhler-Allied 795 loader, 1974 IH 1066 with DT466 and 3LM turbo, 1979 IH 1586, 1991 CaseIH 5140 with westendorf WL-42 loader, IH 510 4 bottom plow (BIL's uncle bought it new and only plowed 20 acers and sat in a shed til i bought it!) John Deere 735 MowCo, Hesston 3940 12 wheel hi-capacity wheel rake, 2012 John Deere 468 with netwrap , 1999.5 Ford F-250 XLT extended cab powerstroke diesel!!
Other colors: '68 JD 2510.
Past tractors:'74 IH 1466 Factory Fender tractor, '84 IH 3688, '74 IH 1466 with Cab, '79 IH 1086 with cab, '78 AC 7060 with cab, '65 AC 190xt, '64 Oliver 1800C, '64 Oliver 1600, '60 Oliver 1900, '63 JD 4010, '92 JD 2555 with cab, '64 JD 3020.
Reply to this topic
