Removing the PTO
13 replies to this topic
#1 davidp
davidp
  • Members
  • PipPipPip
  • 49 posts
  • Gender:Male
Posted 17 April 2011 - 07:00 PM
How big a job is it,to remove the PTO unit from a 1086? Anything i need to pay special attention to?
Thanks,
David
#2 strictly ih
strictly ih
  • Members
  • PipPipPip
  • 90 posts
  • Gender:Male
  • Interests:All things IH
    pedal steel guitar
Posted 17 April 2011 - 07:36 PM
Just the suction tube as it comes through the rear housing and make note that the connecting shaft stays put so the couplings stay oriented in the right direction. You can do this by removing the third link cover and reaching inside to hold it in place. When you re-install it, you will need a pressure guage to adjust the lock up pressure and starting pressures.
3rd generation owner of 1966 706 diesel and 1951 M.
Also 1929 22-36 Mccormick and Cadets 582 and 129.
#3 IH-Harvester
IH-Harvester
  • Members
  • PipPipPip
  • 340 posts
  • Gender:Male
Posted 17 April 2011 - 08:54 PM
Looks tougher than it is.Drain hytrans, remove top link cover, remove the long bolts in the pto housing, disconnect linkage and wiggle it around and out. Pull it out just far enough to break the gasket seal. It's pretty heavy. One guy can take them in and out but it does take a techique to balance it. When you start to pull the unit out, take it slowly and make sure the shaft drives the pto thatinside the rear stays on the inner shaft not the pto unit. It will just kinda hang in there. As you pull the pto unit out furthur start to drop the outside part down a little. The suction tube is on a 45 degree angle pointed down and will not clear the hole if you pull it straight out and will not take too much presure against it or you will damage it or the seal. When you tip the pto down to pull it out, with one hand grab the 1000 shaft and the other hand grab the inner shaft coming out of the pto drive. Watch your toes!!!
#4 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,508 posts
  • Gender:Male
  • Interests:Rebuilding IH farm tractors, Pulling RED tractors, Working in my shop. MOPAR cars. Austrailian Opals
Posted 17 April 2011 - 09:30 PM
I usually attatch a lift on one of the upper bolts, then use a pipe that will slip over the 540 shaft to help guide it out of the housing.
"Rooster" 1066 puller tractor, Soon to be turned back into a farm tractor
 "Banty" 666 7000# Puller toy, 312 3-LM Has stuff done to it.
"Emmy Lou" 1939 M , 1939 Farmall H (to be named later)
'  F-1206, 2WD 5088  1066 to be restored
2 782 Cadets 1 repowered. CanAm OutlanderMax650
2 Dodge Cummins trucks 2013"Buckweet" and 2004 "Duke"
[i][color=#FF0000]
Can am outlander Max, XT Honda ST 1100
Torchmate CNC Plasma cutting table
#5 Owen Aaland
Owen Aaland
  • Members
  • PipPipPip
  • 2,407 posts
  • Gender:Male
Posted 18 April 2011 - 10:07 AM
There is one shorter bolt on the bottom in addition to the long bolts that has to be removed.
#6 Rockymnt
Rockymnt
    Member
  • Members
  • PipPip
  • 13 posts
Posted 18 April 2011 - 02:52 PM
How do you tell which way the coupling shaft goes. The boy is rebuilding with his own money a 1466 turbo for 4H. The pto unit was missing and we found a used one to put in. there was no shaft for reference inside of it. Thanks, sorry for the hijack.
Butch
#7 red convert
red convert
  • Members
  • PipPipPip
  • 428 posts
  • Gender:Male
  • Interests:Farming, Tractors, and all that good stuff!!
Posted 18 April 2011 - 04:57 PM
The PTO was missing? Where did you find the old girl? That sounds like a story in the making.
I want to say the coupler is reversible, so it won't matter. Otherwise it will slip on the shafts in only one way, so it won't matter.
I just did this job on my 2+2, and it is not too bad. There has been good advice: Use a engine crane, Remove the top link so you can see what's going on, and make sure you get all the bolts.
Watch out for your fingers and toes, and you'll be fine.
While you are at, I would suggest to replace the clutch plate if it hasn't been rebuilt already.
And good for your boy! This is a fantastic project! A challenge, but do-able! Good luck!
#8 NE POWESHIEK FARMALLS
  • Members
  • PipPipPip
  • 490 posts
  • Gender:Male
  • Interests:MY INTERESTS?? ANYTHING RELATED TO THE INTERNATIONAL HARVESTER COMPANY.
Posted 18 April 2011 - 08:17 PM
IF YOU CAN NOSE THE TRACTOR DOWN A DECENT HILL OR INTO A DITCH, YOU DO NOT HAVE TO DRAIN ALL OF THE FLUID OUT. OUR LOCAL MECHANIC DOES THIS OFTEN.
MAPLE HILL FARM
GRINNELL, IOWA
BUY THE HIGHEST QUALITY YOU CAN, AND MAINTAIN THE DEVIL OUT OF IT.
PARTSMAN BY TRADE, FARMER AT HEART!
OPERATE 240 ACRE FARM WITH MY FATHER.
PLAY WITH RED "TOYS" EVERY CHANCE I GET!
COLLECTION TO DATE:
1935 FARMALL F-20,1941 M, 1943 H #133390, 1945 H #207344, 1945 INTERNATIONAL A #141050, 1946 B #166057, 1947 H #268779 W' WOODS 60''BELLY MOWER, 1948 M #164860, 1949 M #209408, 1950 MD #220611, 1950 C #49812 W' WF AND C-72 BLADE, 1952 SUPER M STAGE 1 #12188J, 1953 SUPER M STAGE 1 #22399, 1953 SUPER M STAGE 2 #46802, 1954 SUPER MTA #75111, 1955 300 #8506, 1958 INTERNATIONAL 330U #3835 , 1958 450 #24406,1959 FARMALL 240 # 3123, 1961 460 #25524, 1963 560 DIESEL #65002, 1966 656 #23593, 1966 1206 DIESEL #12348, 1971 856 DIESEL M&W TURBO W' FACT. EXCEL CAB #32482, 1976 FARMALL 666 DIESEL #16239, 1979 1486 #23045, 315 COMBINE, 33 LOADER, #8 FIELD CHOPPER, FH CARRIER, 300 ROTARY HOE, 4-56 PLANTER, 510 4 BTM PLOW #1111, #8 2 AND 3 BTM PLOWS, SICKLE MOWER, C-295 SLAT BOTTOM PLOW, C-254 CULTIVATOR, CUB CADET ORIGINAL, 76, 100, 107 HYDRO, 123 HYDRO, 129 HYDRO, 1605,
1941 ALLIS CHALMERS C, 1954 WD-45 #187699
.......AND TO HAUL IT ALL: 1997 FORD F250 W' 7.3L TURBO POWER DIESEL, 2008 KIEFER-BUILT TRAILER. FORD MAKES IT, IH SHAKES IT!!!!
FAMILY TRACTORS/ EQUIPMENT: 1946 H #229968, 1966 706 (263) W' WL-21 LOADER #34394, 1966 706 (291) # 37793, 1976 915 HYDRO (414), 1979 1460 (436), 1976 IH 1300 TRUCK, 37 DISK, 990 MOWER CONDITIONER, 111 ROTARY MOWER, 63 CULTIVATOR, 1150 GRINDER-MIXER.
GONE BUT NOT FORGOTTEN: 1955 400, 1969 856D CUSTOM.
#9 JandM966
JandM966
  • Members
  • PipPipPip
  • 1,470 posts
  • Gender:Male
  • Interests:Tractor pulls, Spending time with the mrs. cologna...and FARMING!!!
Posted 18 April 2011 - 11:00 PM
I twisted the 1000 shaft out my 1086 one year while mowing hay and I did it all myself. I backed the tractor up on the dove tail of the trailer so the front was pointed down and pulled the unit by myself. I only lost a couple of gallons of oil that way. The shaft is reversable. It doesnt matter what side goes where. Ive done several and not worried about the shaft and have been alright. One other thing I do is put loc-tite on the suction tube. It helps to keep it from working out of the unit, use a med grade loctite so you can take it back apart on down the road. Ive also heard of people brassing it, but ive never done that. Good luck!
John
Proud member of DILLIGAF pullers assoc.!
If we give up our right to freedom for security, in the end we have niether. (I think its from an NRA bumper sticker)
If its green you either mow it or spend it!
If it aint red leave it in the shed!
"God bless America and the farmer that feeds your fat a$$!" have that on a bumper sticker
Blowing smoke til Im broke, running red til Im dead.
1943 Farmall B,1964 IH 706(future puller), 1974 IH 966 openstation with a Buhler-Allied 795 loader, 1974 IH 1066 with DT466 and 3LM turbo, 1979 IH 1586, 1991 CaseIH 5140 with westendorf WL-42 loader, IH 510 4 bottom plow (BIL's uncle bought it new and only plowed 20 acers and sat in a shed til i bought it!) John Deere 735 MowCo, Hesston 3940 12 wheel hi-capacity wheel rake, 2012 John Deere 468 with netwrap , 1999.5 Ford F-250 XLT extended cab powerstroke diesel!!
Other colors: '68 JD 2510.
Past tractors:'74 IH 1466 Factory Fender tractor, '84 IH 3688, '74 IH 1466 with Cab, '79 IH 1086 with cab, '78 AC 7060 with cab, '65 AC 190xt, '64 Oliver 1800C, '64 Oliver 1600, '60 Oliver 1900, '63 JD 4010, '92 JD 2555 with cab, '64 JD 3020.
#10 Rockymnt
Rockymnt
    Member
  • Members
  • PipPip
  • 13 posts
Posted 19 April 2011 - 03:48 PM
Thanks fellas, The boy is very excited to get it going. We will probably roll the mains in Saturday, hopefully. then start dropping in the sleeves in. Here is a picture of his 1952 W9 he and I rebuilt for 4H 2 years ago. He won grand champion at the local and then won grand champion at the Colorado State Fair. The W9 sat for 22 years with out a head. Lots of work on this girl. The tractor that is being pulled by the W9 is his new 4H project, he refers to her as Beauty! Crud how do you post a picture ? Got it !
Reply to this topic
