FLUID CAPACITY IN TIRES
13 replies to this topic
#1 F-N-HYMER
F-N-HYMER
  • Members
  • PipPipPip
  • 88 posts
Posted 24 March 2011 - 08:09 PM
How much fluid does 18.4-38 and 13.6-38 tires hold?
#2 Ron K
Ron K
  • Members
  • PipPipPip
  • 951 posts
Posted 24 March 2011 - 08:13 PM
Depends on how full you want them
Here is a couple charts for you
http://www.ballastst...hart-liquid.txt
http://www.tractorsm...ire_Ballast.htm
#3 F-N-HYMER
F-N-HYMER
  • Members
  • PipPipPip
  • 88 posts
Posted 24 March 2011 - 08:31 PM
Thanks
#4 red_reaper
red_reaper
  • Members
  • PipPipPip
  • 9,015 posts
Posted 25 March 2011 - 06:45 AM
I just put 100 gallon in 18.4x38's of alchohol and it brought the fluid line up just above axle high. No sloshing, and worked great.
The farmall resurector. Bringing them back from the dead.
my tractors,steiger panther ST310,1456,782,,656, 756,1256,1206 prototype,2-1206Farmall's,1206 V8 powered, 5488,1460 combine,SC,560,5088 experimental demonstrator, 312 fast hitch gold demonstrator plow.IH 3F cream separator.
familytractors,H,H,SM,504,544,656,656,666,MX,686,706,826,1206,806,806,460,560,10
86,8940,1586,1586,7150,
CM325 stieger, 2010 model 385 Steiger, 2366,2166 combines
#5 Huffy244
Huffy244
  • Members
  • PipPipPip
  • 452 posts
Posted 25 March 2011 - 10:18 AM
I heard you boys out there like to have a cold one now and then but 100 gallons :D ... No seriously, what kind of alchohol? still using cal. or glyserin here yet.
IH all the way. 7120 mfd,5140mfd,1066,986,666,CNH T5050, 34A, lots other red to come and some gone.
#6 Bernie
Bernie
  • Members
  • PipPipPip
  • 558 posts
Posted 25 March 2011 - 11:12 AM
Please help my ignorance. Why alcohol? Is it mixed with water? I would like to put something in my MD tires, but don's care for calcium chloride because it is so corrosive. In Montana, I would need to freeze protect down to below zero or more.
#7 Maynard
Maynard
  • Members
  • PipPipPip
  • 3,391 posts
Posted 25 March 2011 - 05:00 PM
Iron doesn't care how cold it is.
Growing Old Is No Excuse For Growing Up
"Yet people are considered to be "educated" after they have spent so many years in ivy-covered buildings, absorbing the preconceptions that prevail there."
Thomas Sowell
Being happy doesn't mean everything is perfect. It means you've decided to see beyond the imperfections.
"When people get used to preferential treatment, equal treatment seems like discrimination"
Thomas Sowell
#8 JandM966
JandM966
  • Members
  • PipPipPip
  • 1,470 posts
Posted 25 March 2011 - 05:40 PM
We use glychol here, which I think is the same as the alcohol Kristin uses. If Im not mistaken its antifreeze of sorts. Ive found that it doesnt eat up your rims near like calcium does. My 18.4-38's were nearly full on my 14 when I bought it. I drained them and gave the cal. to a neighbor and he put it in his 18.4-34s with some left over. I forget how many gallons it was but I was impressed.
John
Proud member of DILLIGAF pullers assoc.!
If we give up our right to freedom for security, in the end we have niether. (I think its from an NRA bumper sticker)
If its green you either mow it or spend it!
If it aint red leave it in the shed!
"God bless America and the farmer that feeds your fat a$$!" have that on a bumper sticker
Blowing smoke til Im broke, running red til Im dead.
1943 Farmall B,1964 IH 706(future puller), 1974 IH 966 openstation with a Buhler-Allied 795 loader, 1974 IH 1066 with DT466 and 3LM turbo, 1979 IH 1586, 1991 CaseIH 5140 with westendorf WL-42 loader, IH 510 4 bottom plow (BIL's uncle bought it new and only plowed 20 acers and sat in a shed til i bought it!) John Deere 735 MowCo, Hesston 3940 12 wheel hi-capacity wheel rake, 2012 John Deere 468 with netwrap , 1999.5 Ford F-250 XLT extended cab powerstroke diesel!!
Other colors: '68 JD 2510.
Past tractors:'74 IH 1466 Factory Fender tractor, '84 IH 3688, '74 IH 1466 with Cab, '79 IH 1086 with cab, '78 AC 7060 with cab, '65 AC 190xt, '64 Oliver 1800C, '64 Oliver 1600, '60 Oliver 1900, '63 JD 4010, '92 JD 2555 with cab, '64 JD 3020.
#9 Ron K
Ron K
  • Members
  • PipPipPip
  • 951 posts
Posted 25 March 2011 - 08:17 PM
If you don't like calcium use either Rim Guard (it is sugar beet juice) or windshield washer fluid. Both will not eat up the rim.
Both are environmental friendly. I use them because of the areas I work if I would leak Calcium, it would cost a fortune to clean the area up.
#10 Bernie
Bernie
  • Members
  • PipPipPip
  • 558 posts
Posted 25 March 2011 - 10:47 PM
Thanks,
Never thought of something as simple as washer fluid. Around here it comes with alcohol to keep from freezing, so it should work.
