1256 injection pump
6 replies to this topic
#1 super706
super706
  • Members
  • PipPipPip
  • 40 posts
  • Gender:Male
Posted 19 February 2011 - 09:52 AM
I have a customer that pulled off his injection pump to paint the tractor without tying the throttle back. I know, a big no no, now after putting the pump back on I can't get it to bleed out at all. Did something fall apart inside or is this one just being a pain?
Thanks Todd
#2 farmall666
farmall666
  • Members
  • PipPipPip
  • 3,225 posts
  • Gender:Male
  • Interests:HUNTING / FISHING / IH PRODUCTS / WOMEN
Posted 19 February 2011 - 10:24 AM
YEAH THE WEIGHTS INSIDE.. DIRTBOYZ WILL HELP YOU FIX IT. HE WILL POP ON HERE SOON...
#3 Dirtboyz07
Dirtboyz07
  • Members
  • PipPipPip
  • 3,849 posts
  • Gender:Male
  • Interests:5388 (replica prototype) from 1984 , 1976 1086 (first built)1975 1566 cab (all original) 1974 1566 open station,( improved farm, pulling tractor) 1971 1066 narrow front open station,1970 1456 gold demo.1970 1456 narrow front,1984 1420 Combine 1981 782 Cub Cadet 2005 DX24 Case International Compact Tractor
Posted 19 February 2011 - 02:46 PM
You should maybe pull it back off and check for damage ,if nothing is wrong make sure you have the air out to the fuel inlet on the pump then loosen 3 of the fuel line bolts at the pump and turn the engine until fuel starts to come out those lines. After this you can just tighten the lines and it should start If things are broken just let me know and you can ship it to me and I can get you fixed back up.
Good luck, Danny
[size=2] '84 5388 (replica prototype), '05 International CXT (Former International Show Truck), '75 1566, '71 1066 (narrow front open station), '84 1420, '81 782 Cub Cadet[/size]
#4 super706
super706
  • Members
  • PipPipPip
  • 40 posts
  • Gender:Male
Posted 19 February 2011 - 04:36 PM
I had all the lines off the injectors, filled the fuel system and put air on to try and force feed it, pulled the top cover and filled with fuel, and loosened the outlet port on the bottom of the charge port. I also took the timing cover off and it does turn the timing marks, so is there someting that connects the rest that would be broken?
#5 Dirtboyz07
Dirtboyz07
  • Members
  • PipPipPip
  • 3,849 posts
  • Gender:Male
Posted 19 February 2011 - 04:52 PM
Well sounds like it's BROKE !!!! just pm me if you need help.
Danny
#6 IHBRAD
IHBRAD
  • Members
  • PipPipPip
  • 818 posts
Posted 19 February 2011 - 07:49 PM
The metering valve is probably stuck. This can happen when the throtte is tweaked on a bit. You will need to pull the top cover and flick it back into position. Been there done that.
#7 Injpumped
Injpumped
  • Members
  • PipPipPip
  • 599 posts
  • Gender:Male
  • Interests:motorsports, mostly tractor pulling, and drag racing. Now owner of Guenther Heritage Diesel, specializing in fuel injection systems on heritage era tractors.
Posted 19 February 2011 - 08:25 PM
The metering valve is probably stuck. This can happen when the throttle is tweaked on a bit. You will need to pull the top cover and flick it back into position. Been there done that.
If the pump had been sitting for a while, the plungers could be stuck. Odds are if the weights had fallen out of position, there would have been difficulty sliding the pump over the driveshaft.
Reply to this topic
