560D timing marks
4 replies to this topic
#1 red5770
red5770
  • Members
  • PipPipPip
  • 264 posts
  • Gender:Male
  • Interests:IH tractors and equipment,
    70 Chevelle SS 396
    57 Chevy Bel Air
    Camping with family and friends.
Posted 07 December 2010 - 03:26 PM
I bought a 560D basket case that took 2 loads to get home and hasn't run for 2 years. Got the pump rebuilt and want to make sure I know where TDC is. I have no T or rivet for TDC, has R, A and 50 degree marks. Am I correct to think that TDC is 10 Degrees from the last retarded mark? Static timing marks line up when set to 3 degrees advanced.
Thanks, Steve
1963 IH 606, Kelly loader 311 plow 3X16
1960 560 Diesel, 540 plow 4X16
1959 460 Diesel, 412 plow 4X14
1957 Farmall 450, 412 plow 4X16
1955 Farmall 300, 34-F20 2X14
1955 Farmall 100, L59 Woods mower
1948 Farmall Cub
#2 rustred
rustred
  • Members
  • PipPipPip
  • 168 posts
  • Gender:Male
  • Interests:collecting IHC stuff,auction sales.
Posted 07 December 2010 - 05:42 PM
Thanks, Steve
i am sure if you look closer or clean the pulley you will find 0 degrees on it. should be in the middle of the timing marks, as one way is advance and the other retard.just because the static marks are lined up does not mean anything unless you have the pointer set on 3 degrees.
#3 SMiller
SMiller
  • Members
  • PipPipPip
  • 5,583 posts
  • Gender:Not Telling
Posted 07 December 2010 - 07:23 PM
That motor has to have no. 1 at TDC or it will be 180* off. What all marks do you have between A and R? I was thinking my 560D had a T for 0* but it has been a long while.
Just because the lines line up at 3* does not mean its timed right, you HAVE to find TDC on no. 1, much easier to do it right then have to time it twice.
You might be able to use chalk to color the pulley and wipe off the excess and still have chalk inside the engraved marks showing the marks you cant see to the eye.
Did you put a new governor ring inside the pump? You might be wasting your time if you didnt.
#4 red5770
red5770
  • Members
  • PipPipPip
  • 264 posts
  • Gender:Male
    70 Chevelle SS 396
    57 Chevy Bel Air
Posted 07 December 2010 - 09:25 PM
Thanks for the replys.
With glow plugs out and valve cover off, #1 valves both loose, #6 has one tight and the timing marks are at the pointer. I've already cleaned and chalked the area between the R and A. There are 50 degree marks between R an A, no T or 0 to be found. IT manual shows a T near the R (maybe 10 degrees) in a picture. Pump guy also thought 10 from last retarded mark. The pump and gear are both near the middle of their adjustments. Thanks, Steve
1948 Farmall Cub
#5 Owen Aaland
Owen Aaland
  • Members
  • PipPipPip
  • 2,400 posts
  • Gender:Male
Posted 08 December 2010 - 11:00 PM
The timing marks should go from 10 degrees Retarded to 40 degrees Advanced. If all the timing marks are correct on the timing gears on the front of the engine and the dimples are matched on the pump drive shaft and the rotor in the pump you should be on the correct cylinder.
Reply to this topic
