1066 540 Shaft replacement
8 replies to this topic
#1 WishIhada1466
WishIhada1466
  • Members
  • PipPipPip
  • 386 posts
  • Gender:Male
  • Interests:Red tractors and trucks with Bowties.
Posted 02 December 2010 - 12:12 PM
I have a buddies 1066 in the shop with a bent 540 shaft and bad bearing and seal. Is it possible to remove the rear PTO housing cover and just replace the 540 shaft, bearing and seals without disassembling the entire PTO? In the exploded view it looks like that the 1000 shaft seal and snap ring could be removed the rear cover would come off leaving the 1000 shaft with the PTO clutch housing and the 540 with the rear cover. I don't think it works that way but my Uncle is argueing with me and I am out to prove him wrong and I want to do the job right the first time. I am almost positive the entire thing needs to be disassembled to make this repair. I rebuilt the PTO on an 806 last fall but I had it completely disassembled and I don't exactly remember what it looked like in there. Any help would be appreciated. Thanks.
1979 Chevy K30, 350, 4 speed
#2 aar
aar
  • Members
  • PipPipPip
  • 1,123 posts
  • Gender:Male
  • Interests:All things IH, from Cub Cadets to Pullers and most everything in between
Posted 02 December 2010 - 12:25 PM
U win!!! it must be completely removed and disassembled to replace it ;)
806d,450g, 45M,53 golden jubilee, building pullers
#3 Sparky
Sparky
  • Members
  • PipPipPip
  • 2,576 posts
  • Gender:Male
Posted 02 December 2010 - 01:43 PM
Yup...what aar said. That 540 shaft is the last thing to come out.
Travis
'74 966, '46 H, Two 990 mower conditioners, #15 rake and a #35 behind it, 241 bigroll baler, 560 plow, #37 disc, 19' 45 F.C. and a couple other off breeds. Got a 782 Cub Cadet, also. Not much else, but it keeps me out of trouble!
Money is NOT the root of all Evil, Lack of money is the root of all Evil...
#4 WishIhada1466
WishIhada1466
  • Members
  • PipPipPip
  • 386 posts
  • Gender:Male
Posted 02 December 2010 - 03:21 PM
What exactly is keeping that cover from coming off? Just so I know and can tell him exactly why, because he will want to know. It does appear in the IT manual exploded view that it would come off if you removed the 1000 seal and snap ring, but alot of times you can't see everything as it is. Thanks fellers.
#5 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,508 posts
  • Gender:Male
  • Interests:Rebuilding IH farm tractors, Pulling RED tractors, Working in my shop. MOPAR cars. Austrailian Opals
Posted 02 December 2010 - 03:25 PM
Even if it was possible to remove the rear cover there is a snap ring on the 540 shaft that would prevent its removal from the inner housing.. I think you should sneek back into the shop in the evening and just yank the entire PTO unit out and go through the complete assembly properly.
"Rooster" 1066 puller tractor, Soon to be turned back into a farm tractor
 "Banty" 666 7000# Puller toy, 312 3-LM Has stuff done to it.
"Emmy Lou" 1939 M , 1939 Farmall H (to be named later)
'  F-1206, 2WD 5088  1066 to be restored
2 782 Cadets 1 repowered. CanAm OutlanderMax650
2 Dodge Cummins trucks 2013"Buckweet" and 2004 "Duke"
[i][color=#FF0000]
Can am outlander Max, XT Honda ST 1100
Torchmate CNC Plasma cutting table
#6 Sparky
Sparky
  • Members
  • PipPipPip
  • 2,576 posts
  • Gender:Male
Posted 02 December 2010 - 03:51 PM
Right, because you're gonna have a heck of a mess on your hands if you try to pull the outer cover off before pulling out the whole assy.
Travis
#7 WishIhada1466
WishIhada1466
  • Members
  • PipPipPip
  • 386 posts
  • Gender:Male
Posted 02 December 2010 - 04:42 PM
I intend to do it properly. With the exception of clutches. I can't convince my buddy that while I've got it apart that he should install new clutches. O well, its his tractor I reckon.
#8 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,508 posts
  • Gender:Male
Posted 02 December 2010 - 08:11 PM
While you are in there at least inspect the clutches. VERY easy to do, just remove 4 bolts,pull off the hub assembly,remove ONE snapring and the clutches just about jump into your hand. You will never be closer to this simple operation.
[i][color=#FF0000]
#9 aar
aar
  • Members
  • PipPipPip
  • 1,123 posts
  • Gender:Male
Posted 03 December 2010 - 09:32 AM
you'll have them out anyway to get to the 540 shaft so u will have the visual to show your buddy if they need replaced, just have a new disc there to compare to ;)
Reply to this topic
