REbuilding Farmall M Engine
#1
Posted 27 August 2010 - 06:21 AM
#2
Posted 27 August 2010 - 07:11 AM
If your sleeving the engine, then I'd order the pistons, rings and sleeves as a matched set. My engine didn't need sleeves, I honed it and put new rings back on the old pistons. As to the rod orientation...sounds to me like someone has already been into it once and put it back together incorrectly. Without out having a rod in my hands to look out, I'm not sure if the oil galleys were lined up, plus I don't believe the rods are exactly centered either...something makes me think the wrist pins may infact be slightly offset from the crank journals...
1951 Farmall "M"
1949 Farmall Cub - Original "Blue Ribbon Reconditioned"
1929 Farmall Regular
1956 Ford 640
1967 John Deere 112H
1973 John Deere 140 H3
1985 John Deere 420
1999 F350 6.8L V10 DRW 4X4 Supercrew XLT Lariat
#4
Posted 27 August 2010 - 07:48 AM
#5
Posted 27 August 2010 - 11:17 AM
4" bore is "standard" for the late M's and Super M's using the C-264 engine, early M's with the 247 will measure around 3-7/8". Like Dukester said, I'd have it checked for bore and taper before condemning anything.
Whether or not to have the head done is your call. Simply lapping the valves by hand and readjusting the valves may be all that is required.
1951 Farmall "M"
1956 Ford 640
1985 John Deere 420
#6
Posted 27 August 2010 - 07:03 PM
I was taught and followed the rule that if the sleeves weren't worn more than .003 per inch of cylinder diameter, out of round more than .002 per inch of diameter or not scored so bad that the normal glaze busting/ honing couldn't clean it up, it would be okay to reuse the sleeves or not have to bore the block if there were no sleeves. Pistons have to have the ring grooves/lands checked for excessive wear and the skirt diameter measured for wear (not to exceed .002 inch per cylinder diameter). Of course a lot depends on how the tractor is going to be used after the repair/overhaul. If it's going to be subjected to heavy use and loads, replacement of all "borderline parts" is essential for the engine to last a reasonable amount of time. On the other hand, a tractor used for show, parades and general light occasional usage can have it's engine reassembled with "good worn but useable parts" and be reliable and last indefinately. Either way it's absolutely essential that the engine be reassembled correctly regardless of how it was when torn down.
What he said!
"In America, anyone can be president. That's just one of the risks you take."
#8
Posted 28 August 2010 - 01:54 PM
I'm rebuilding my Farmall M Engine, had crank problems. Is it necessary to replace the pistons, I know I need new sleeves as it had been burning oil, ever since I've owned it. Just didn't know whether I really need to repalce the pistons or if it is just a good pratice. Also noticed in my reapir manual that it said the side of the rod that has the number stamper in the block and rad is on the camshaft side of the engine. Mine wasn't that way when I pulle dth pistons out. Any thoughts?
If you hold the rod by the small end and let the rest hang down, the side that hangs lowest with the cap off goes toward the camshaft side. Would check the piston ring groves for taper and width. If you have 4 inch bore firecrater pistons they were hard on the top ring grove unless timing, fuel and load were kept in the correct range. Dave
#9
Posted 30 August 2010 - 05:44 AM
#10
Posted 30 August 2010 - 06:18 AM
Grandpa's Surer H, 1944 H, My ole 1066, 710 6-16 Automatic, Little Genius plows, 1 and 2 bottom ,2 bottom Little Wonder,2-#27V mowers, a #25 mower, #7 mower, 240 HM, 2 row cultivators, High wheel McCormick grain drill, S-3 Cream Separator. Collecting ole Red Iron can be expensive, But It sure is fun.
