560 3pt. hitch
15 replies to this topic
#1 ken ryan
ken ryan
  • Members
  • PipPipPip
  • 1,076 posts
  • Gender:Male
  • Interests:I like to restore farm machinery, especially when it is red. I'm a retired mechanical engineer living on a small farm. Fresh out of college I worked for IH at the the research center in Hinsdale, Illinois.
Posted 29 July 2009 - 01:15 PM
I'm considering converting a Farmall 560 to 3 point hitch. What do you think? We love the 560's for haying. I would like to run a 990 mower conditioner, a new small square baler and a 7 ft. Bush Hog (requires 3 pt. hitch). The open station 560 is great for haying. Visibility is good. The live PTO works great. It is just the right size. Thanks for any opinions. Ken Ryan
#2 laportej
laportej
  • Members
  • PipPipPip
  • 362 posts
  • Gender:Male
  • Interests:Work in Agronomy Sales
Posted 29 July 2009 - 03:22 PM
Do you already have the fast hitch on it or standard drawbar? If you've got the fast hitch, there's an easy way to make it a 3pt hitch with a little shop work. Let me know what you have and if you've got the fast hitch I'll take some pictures of what we did to ours to make it really simple. We don't use the 3pt hitch, but we've got it set up that we can anytime we need to.
Rocky View Farms
Cassopolis, Michigan
"Drive It Like You Stole It!"
IH 686 German Diesel (1980)
IH 1066 Black Stripe (1976)
Farmall 656 Diesel (1971)
Farmall 560 Diesel (1962)
Farmall 300 Gas
Cub Cadet 482
#3 red_reaper
red_reaper
  • Members
  • PipPipPip
  • 8,964 posts
  • Gender:Male
  • Interests:my tractors,steiger panther 310,1456,782,656,SC, 756,1206 V8,2-1206Farmall's,5488,2166,560,806,7240, Gold demonstrator 312 fast hitch plow. HSWJ
    familytractors,H,H,SM,504,544,656,656,666,MX,686,706,1206,1206,806,806,1086,460,1086,8940,1586,1586,7150,325 stieger 2366,2388,Steiger 380,5240,826
Posted 29 July 2009 - 05:21 PM
I'd like to see pictures of how you made a 3pt out of a 2pt. Regular slide in adaptors don't work well, and I just bought dad a 2 to 3 point IH A frame adaptor at RPR. Curious how you did yours.
The farmall resurector. Bringing them back from the dead.
my tractors,steiger panther ST310,1456,782,,656, 756,1256,1206 prototype,2-1206Farmall's,1206 V8 powered, 5488,1460 combine,SC,560,5088 experimental demonstrator, 312 fast hitch gold demonstrator plow.IH 3F cream separator.
familytractors,H,H,SM,504,544,656,656,666,MX,686,706,826,1206,806,806,460,560,10
CM325 stieger, 2010 model 385 Steiger, 2366,2166 combines
#4 cm228
cm228
  • Members
  • PipPipPip
  • 491 posts
  • Gender:Male
Posted 29 July 2009 - 05:46 PM
laportej is right it is easy to make a 3pt adapter out of a 3pt fast hitch. I built one for my 400 a couple of years ago. I got a 3pt fast hitch from tractor supply. and took the points that I got with my 540 4 plow. I welded some heavy steel to the top of the points making an " L " shape. on the 3pt fast hitch I welded more steel to the fast hitch frame with a slot between them to pin the top of the L shape points to it. I'll get some pic's tomorrow when it stops raining here. It works well. I think this would be easier than trying to switch 2 pt to 3pt. plus you get to keep your 560 original ( if that matters to you ).
Full time diesel mechanic for Cummins Power Systems LLC.
Part time hobby farmer
My tractor Farmall 400 Diesel
Dad's tractors Super H, H, Farmall Cub 1782 Cub Cadet
Brother's tractors H, Super C
#5 Duane966
Duane966
  • Members
  • PipPipPip
  • 321 posts
  • Gender:Male
  • Interests:farming, sports, collecting toy tractors
Posted 29 July 2009 - 06:49 PM
we took the swinging draw bar off of our 560
many years ago and put on this 3 point hitch.
i think it is a work saver. l like the 2 lift cylinders.
we added the remotes to the hitch when the
560 was our planting tractor. had to take off
one remote for the 686 when it started to leak.
the 3 point arm is a great step.
hth
Duane
1984 5288, 1981 3688, 1958 560, H,
1986 CIH 1620, 1999 3/4T dodge cummins 4x4
#6 redtroy
redtroy
  • Members
  • PipPipPip
  • 360 posts
  • Interests:grew up on red tractors ,, even my wife has red hair
Posted 29 July 2009 - 07:06 PM
Sorry to get off topic a bit , ,,, how does your 560 handle the baler?? We had an international 3 somthing (328/348) cant remember exactly baler , anyways we used the 560 on it for two loads only because the plunger cycling just pounded the tractor all to he#@. Just a constant rrrrr,,rrrr,,,rrrr,,,rrr as you went down the windrow...Had a 706 german diesel that worked much better.
out of the farming mix for over ten years ,, was raised on a 1466 ,,1586,,and a pair of 5088's ,,flying a private jet in the interim for the rich and overprivlaged trying to make enough to have fun farming again
#7 laportej
laportej
  • Members
  • PipPipPip
  • 362 posts
  • Gender:Male
Posted 29 July 2009 - 08:50 PM
We still have the fast hitch on the tractor and don't use the 3pt, but we've still got the prongs lying in the shop and the third arm hook-up is still on the tractor. I'll take some snaps of it all while I'm home this weekend and post them up. It's pretty simple to do and doesn't take much steel to do it.
Rocky View Farms
Farmall 300 Gas
Cub Cadet 482
#8 ken ryan
ken ryan
  • Members
  • PipPipPip
  • 1,076 posts
  • Gender:Male
Posted 30 July 2009 - 04:10 AM
I have rigid drawbar now. There is no hitch.
Thanks.
Ken Ryan
#9 ken ryan
ken ryan
  • Members
  • PipPipPip
  • 1,076 posts
  • Gender:Male
Posted 30 July 2009 - 04:14 AM
The 560 does well, with a 9 X 18 wagon behind on our NYS hills. The power is just a perfect match. Our baler is the middle 14 X 18 Case/IH New Holland makes now. We have a 1066 but I don't like being in a cab and that is too much tractor. Thanks. Ken Ryan
#10 cm228
cm228
  • Members
  • PipPipPip
  • 491 posts
  • Gender:Male
Posted 30 July 2009 - 03:30 PM
well as promised here are some pics of my 2pt to 3pt adapter.
Reply to this topic
