chainsaw wont run sideways
18 replies to this topic
#1 red_reaper
red_reaper
  • Members
  • PipPipPip
  • 9,010 posts
  • Gender:Male
  • Interests:my tractors,steiger panther 310,1456,782,656,SC, 756,1206 V8,2-1206Farmall's,5488,2166,560,806,7240, Gold demonstrator 312 fast hitch plow. HSWJ
    familytractors,H,H,SM,504,544,656,656,666,MX,686,706,1206,1206,806,806,1086,460,1086,8940,1586,1586,7150,325 stieger 2366,2388,Steiger 380,5240,826
Posted 19 July 2008 - 07:58 PM
Have a old super low hr. Homelite 2 chain saw, still has the original bar that looks like new. I've used it for odd small stuff for years, and has allways ran good but not much power. as to be expected for such a little chain saw. Its very handy and light weight. I set 21 wooden posts made from old telephone poles. I was going to saw them off even and discovered the chain saw wont run when you turn it on its side, just runs out of power and stalls. I filled the gas up to the top and still did it. Any ideas I can try? I hate to use my other homelite super XL12, the old blue model, when on its side what muffler it has is right in your face and very loud, plus its heavy and has a too long a bar for what I'm doing,and I'm doing it at eye level, so the smaller ones easier to keep from cutting my head off.
The farmall resurector. Bringing them back from the dead.
my tractors,steiger panther ST310,1456,782,,656, 756,1256,1206 prototype,2-1206Farmall's,1206 V8 powered, 5488,1460 combine,SC,560,5088 experimental demonstrator, 312 fast hitch gold demonstrator plow.IH 3F cream separator.
familytractors,H,H,SM,504,544,656,656,666,MX,686,706,826,1206,806,806,460,560,10
CM325 stieger, 2010 model 385 Steiger, 2366,2166 combines
#2 HYTRAN
HYTRAN
  • Members
  • PipPipPip
  • 456 posts
  • Gender:Male
Posted 19 July 2008 - 08:17 PM
Not familiar with that saw but only thing that comes to mind is if it has a small line inside the tank that is broke or even cracked. Not sure on shape of tank but even full when filling might still have an air cavity when turned sideways.
#3 BOOMER
BOOMER
  • Members
  • PipPipPip
  • 3,698 posts
  • Gender:Male
  • Interests:Anything IH Red or Ford Blue
Posted 19 July 2008 - 08:23 PM
Hello all , Kinda what I was thinking . I have a leaf blower that the line rotted off inside the tank :angry: . Runs good about any direction except pointed at the ground to work . Boomer
1938 Farmall F-20  , 1954 Farmall Super M-TA Gas, 1959 Farmall 560 Turbo Diesel with Woods belly mower , 1967 Farmall 656 Hydro Diesel , 1969 Farmall 856 Custom Turbo Diesel with a Westendorf loader & Hiniker Cab
#4 Old-F20
Old-F20
  • Members
  • PipPipPip
  • 3,914 posts
  • Gender:Male
  • Interests:Professional BUM, Part time Slacker, antique tractor and car restorer
Posted 19 July 2008 - 09:35 PM
LMAO :lol: :lol: kinda how htings work around here
more than likeley the fuel line issue is what you have, or the fact its a homelite :blush:
"It takes less time to do something right than it does to explain why you did it wrong" Grandmas advice
GENIUS BY BIRTH, SLACKER BY CHOICE
#5 jamesthomas
jamesthomas
  • Members
  • PipPipPip
  • 84 posts
  • Interests:Being a Fightin Texas Aggie! Anything with gears, pulleys, motors, wheels
Posted 20 July 2008 - 12:28 AM
Reaper,
I would look at two things.
1) As the others have stated, check the gas lines. There may be a crack in the lines allowing air to get into the system. Since you stated that you have filled the tank and it still acts up, the leak may be in the part of the line not in the tank.
2) Another problem that I would check are the diaphragms in the carburetor. These serve as a fuel pump which in turn allows the saws to be operated at many angles. Over time, these become hard, brittle, and succeptible to cracking probibiting the transfer of fuel to the cylinder when you go to make a cut.
Hope this helps.
JTF
#6 redgreen
redgreen
  • Members
  • PipPipPip
  • 4,856 posts
  • Gender:Male
  • Interests:Are you kidding?
    Tractors - what else!
Posted 20 July 2008 - 06:21 AM
I agree with these guys, it's probably sucking air. Also keep in mind that this older saw might not like the the alcohol in the gas that we have now and that may have damaged the plastic fuel line by making it brittle.
What ever you do don't junk that saw. Believe it or not some people COLLECT chainsaws.....just like tractors!
:P
But seek first his kingdom and his righteousness, and all these things will be given to you as well. Matthew 6:33 NIV
In the shed: '42 "H", '45 "H", '49 "M" & some GREEN stuff too. Oh, get over it.....they're all old and still run!
Posted Image
#7 red_reaper
red_reaper
  • Members
  • PipPipPip
  • 9,010 posts
  • Gender:Male
Posted 20 July 2008 - 09:27 AM
Jamesthomas, that might make sense that the crack is on the outside of the tank,whowever its not leaking, cause if the crack was on the inside it would at least run on its side flipped over one way,and maybe not the other,but this is both ways. It just pulls down to a idle and the chain stops just like the chain is too tight. I'll pull the case apart to see what those lines are like. I just had it off the other day to repair the rope that I pulled out of it from it not starting and me going wild pulling that rope, too bad you cant hook a chain up to them and pull start them like a tractor, sometimes you need to. Next chainsaw will be a stihl
redgreen, dont worry I will not junk this saw, its too handy and just like new. The Super XL12 I have also still had the original bar on it when I got it. I put a new one on a few years back but it also is like new, just wish it had the automatic oiler. That thing has gobbs of power,and the only two complaints I have on it is the manual oiler and that super loud exhaust. I believe those old blue homelites are starting to become more collectable. We have a old Pioneer chainsaw setting in the corner, its bright yellow. I could never get it to run though.
#8 MOChad
MOChad
  • Members
  • PipPipPip
  • 6,190 posts
Posted 20 July 2008 - 10:08 AM
Dad's got a Stihl farmoss that hasn't had two tanks of gas run through it I'll trade for your pressure washer. :ph34r: .
Present CaseIH 7140, 7120, 5240, 5140, IH 5488, IH 1466, 966. 1480
Family IH's past M, 400x2, 450, 460x2, 706G, 856, 1256, 966, 1086, 895CIH
Too bad Ignorance isn't painful!
#9 superHTA
superHTA
  • Members
  • PipPipPip
  • 1,729 posts
Posted 20 July 2008 - 12:08 PM
:P
That is for sure..........unfortunately I seem to have become one of them :blush: I started out with an 031 that I picked up for 20 bucks, ran like a champ, used it for a couple of years til it gave me some trouble about not wanting to stay running. Took it in to see if it was beyond hope, compression still seemed good. I got it back at the same time they were having a sale on Stihl, so I was going to replace it if it wasn't worth fixing or buy a smaller saw that would be newer and handier (Mini Boss) (as well as something of a backup due to the age of the 031) The 031 only took fuel lines and carb diaphrams, used it to make two cuts and it went back to doing what it did before, took it back and ended up getting a 390 because I was into a job that was going to be a real challenge to make it through with the 031 (told the guy that "I guess if I buy enough Stihl saws, I might get the job done." I got the 031 back but haven't used it to see if it will still go. The 390 is awsome :D
So I went from having one Stihl to having three :blush:
Posted Image
"The tree of Liberty must be refreshed from time to time with the blood of patriots and tyrants." Thomas Jefferson
"America is at that awkward stage. It's too late to work within the system, but too early to shoot the ba$tards." - Claire Wolfe
So little time, so many tractors. Cub Cadet: 149, 1650, 1864, tractors: F-12,(2)F-20's,(2)H's,OS-4, SHTA,M,SM,SMTA,O-6, 450,450D,656D utility,574, and last but not least a 1456
#10 dwightc
dwightc
  • Members
  • PipPipPip
  • 838 posts
Posted 20 July 2008 - 05:21 PM
I'm not positive on this, but I think the Super XL had both a manual oiler and an automatic oiler. We had one, I'm almost positive it oiled on it's own.
l8r
Reply to this topic
