900 Case IH planters
4 replies to this topic
#1 Turbo_1066
Turbo_1066
  • Members
  • PipPipPip
  • 163 posts
Posted 24 June 2008 - 06:05 AM
Well in the last couple of years I have worked to weed out all of our green equipment. I just traded the John Deere combine off last week. Now I have found a Case IH 900 planter that is a 12 row 30". It has residue manager and no fertilize which is fine. It also has a kelderman fold system on it. I need to know if a 1066 will handle that planter ok in the hills. I also need to know about no-tilling with these planters, I was told you do not need any no-till coulters with a red planter. So any help will be much appreciated. Thanks, Keith
Super M, Super M-TA, Farmall 95c, 1066, Maxxum 125, 7130, 9250, 9380, 8010, 2013 F 350 PSD, 2003 IC school bus
#2 XJCraver
XJCraver
  • Members
  • PipPipPip
  • 391 posts
Posted 24 June 2008 - 06:10 AM
The 1066 should pull it fine; you might want to be dualed-up if it's slippery. As far as the coulters, I'm no help on that one.
-J
Starvation Acres Farms - Greenville, IL
'68 756 - '60 560 - '79 1486 - '82 1480 Combine/ 20' 1020/ 6 row 1063 - '78 CargoStar 1810B - '79 JI Case 970
470 manual fold disc - #60 Disc Chisel - 3- #45 field cultivators - 540 f.h. plow 820 Massey disc - '72 Chevy C50
#3 MOChad
MOChad
  • Members
  • PipPipPip
  • 6,190 posts
Posted 24 June 2008 - 06:43 AM
Just finished no-tilling a couple hundred acres with an 800 with rowcleaners and no coulters and the row cleaners are really optional. I actually like the row cleaners better in rough conventional till over no-till. Never seen a Keldermann fold on a 12 row. Used to be several 8 rows around, though.
Present CaseIH 7140, 7120, 5240, 5140, IH 5488, IH 1466, 966. 1480
Family IH's past M, 400x2, 450, 460x2, 706G, 856, 1256, 966, 1086, 895CIH
Too bad Ignorance isn't painful!
#4 DaveM
DaveM
  • Members
  • PipPipPip
  • 57 posts
Posted 24 June 2008 - 08:01 AM
I have a 800 12-30 with yetter row cleaners and it does a good job in no-til. I also built a 13-15" bean planter that has yetter no-til coulters on it. I no-til most of my beans so that is the reason for the no-til coulters. I don't think you need them but I do think it will make your double disc openers last 3 times as long as they are always in loose dirt and not doing all the work on cutting the hard soil.
Restored 1977 4186 4X4. One of 333 built in 1977. 1955 300 Farmall bought new by my Grandpa still on original rubber all the way around. Plain Jane...no live PTO, no fast hitch, no T/A, no power steering, NO FRILLS!!!
#5 Mike Besse
Mike Besse
  • Members
  • PipPipPip
  • 450 posts
Posted 24 June 2008 - 08:05 PM
The 10 should pull it just fine, with or without duals, unless your ground is really rolling, then put the duals on. I dont use coulters because they throw dirt, I have used my row cleaners 1 out of the last 5 years becaus if it gets hairy they just ball up causing problems. I use spikey closeing weels to work a litte strip of dirt over the row, rebounders to tuck the seed in the bottom of the trench, and put the molding between the rows of hole on the drum so it turns smooth. Check all your chains and bearings, make shure the bearing is good in the wheel that runs inside the drum, check the brush, shoot for medium-round seed, check the firming points and seed shoes and keep it around 4 to 5 mph and you will be fine. I no-till 99% and it does great.
I farm with a 460, 1456, and a 1440. Everything I run is IH except the M&W graincart, but it's RED!
I work at a machineshop to support my farming habit.
