International 330
8 replies to this topic
#1 kneepads
kneepads
  • Members
  • PipPipPip
  • 48 posts
Posted 23 April 2008 - 03:22 PM
Hey Guys,
Found a little 330 international today, are these worth anything?
Stew in AZ
#2 retento
retento
  • Members
  • PipPipPip
  • 2,305 posts
Posted 23 April 2008 - 04:10 PM
Not too many of them around, built in 57 & 58. I have never laid a hand on one.
A few little details...
International Harvester 330
General tractor information:
Manufacturer: International Harvester
Model: 330
Type: Farm/Agricultural tractor
Years produced: 1957 - 1958
Total built:
Factory:
Original price: $2,900 (1958)
Tractor power:
Drawbar (rated): 31.7 hp [23.6 kW]
Drawbar (max): 31.8 hp [23.7 kW]
PTO (rated): 34.24 hp [25.5 kW]
Engine:
Model: C135
Fuel: gasoline
Cylinders: 4
Bore/Stroke: 3.25x4.0625 inches [83 x 103 mm]
Displacement: 134.8 ci [2.2 L]
Compression: 7.38:1
Rated RPMs: 2000
Cooling: liquid
Coolant: 14 qts [13.2 L]
Torque:
Firing order:
Transmission:
Type: sliding gear
Forward: 5
Reverse: 1
Transmission:
Type: Torque Amplifier
Forward: 10
Reverse: 2
Mechanical:
Chassis: 2WD
Steering:
Brakes:
Capacity:
Fuel:
Power Take-off (PTO):
Rear PTO: independent
Rear speed (RPM): 540
Tires:
Ag front: 5.50-16
Ag rear: 11-28
Dimensions:
Weight: 3924 lbs [1779 kg]
Wheelbase:
Length:
Width:
Height:
Ground clearance:
Electrical:
Nebraska Tractor Test 634:
Test Date: November 1957
Engine: gasoline
Belt (max): 34.2 hp [25.5 kW]
#3 Mr. Brookville
Mr. Brookville
  • Members
  • PipPipPip
  • 737 posts
Posted 23 April 2008 - 04:12 PM
I have one and love it. It's a low powered 300 or 350 utility. I rake hay with mine and plow neighbor hood gardens with a mounted 2 bottom plow. it it has power steering and it works you have a real handy little tractor
I believe they were put out to compete with the very popular 8N. about the same HP but a lot easier to work on and with fast hitch.
Mr. Brookville
#4 CNKS
CNKS
  • Members
  • PipPipPip
  • 643 posts
Posted 23 April 2008 - 06:17 PM
The 330 was the forerunner of the 340. IH was not yet ready to introduce the 340, so put the 340 engine, a C135 (same basic engine as the C123) into the 350, along with some other changes, and called it the 330. When the 460U was introduced as a replacement for the 350U, there was a large power/size gap between the 240 and the 460. The 330, then the 340 were meant to fill the gap -- at least that is my understanding. I think there was some overlap between the 330 and the 350, also. Someone with more knowledge of the situation can correct me.
#5 Dax DeCelle
Dax DeCelle
  • Members
  • PipPipPip
  • 1,622 posts
Posted 23 April 2008 - 07:22 PM
I WOULD CONSIDER THEM VERY COLLECTIBLE AND QUITE RARE. I WOULD LOVE TO HAVE ONE. IS THIS ONE FOR SALE? MAN, I WOULD TRY AND GET IT IF IT IS AVAILABLE. JUST MY 2 CENTS. WHAT PART OF AZ ARE YOU IN? I LIVED IN TUCSON FOR 2 1/2 YEARS, AND NO I WASN'T AT DAVIS MONTHAN.
1945 AI, 1946 H, 1946 M, 1948 H, 1950 Farmall Cub, 1951 Super C, 1953 Super C, 1953 Super H, 1957 350 Utility, 1962 B450, 1976 185 Loboy, 1976 Cub Cadet 1450 with Model 2 tiller, 1975 Cub Cadet 1650, 1953 U1 power unit, 1948 KB 7, 1964 C1300, 1965 Loadstar CO 1800, 1966 1000A Step side, 1973 1510, 1978 Loadstar 1600 dump truck, several parts tractors, 1300 sickle mower, 1965 MF 3165 with 200 Loader and 220 backhoe, 1964 Minneapolis Moline M602 LP, 1988 Ford F250 with International 7.3L diesel
#6 53superH
53superH
  • Members
  • PipPipPip
  • 130 posts
Posted 23 April 2008 - 07:53 PM
We have one that we restored. I think IH marketed them with loaders and backhoes. Does anyone know the correct steering wheel is for it ?
#7 Paul DeWitte
Paul DeWitte
  • Members
  • PipPipPip
  • 337 posts
Posted 23 April 2008 - 08:03 PM
I believe the 330 and 350 were available at the same time. I remember one that we sold that was used for a loader tractor.
The 330 had the 350 trans/rear end and the 340 engine. not sure what it had for a loader but we sold quite a few Superior loaders. They seemed to be a little better than the IH loader for the 300/350.
#8 Hoot
Hoot
  • Members
  • PipPipPip
  • 3,087 posts
Posted 24 April 2008 - 06:25 AM
I don't know anything about the engine sizes or what tractors they went into but I was led to believe that the 350 was a descendent of the Super H and the 330 was the descendent of the Super C.
Git-R-Done with a 2 way plow, one way plows are for show, parades, and plow days.
IH Equipment; '68 656D, 642 4 Bottom Rollover Plow, 535 3 Bottom Semi-mounted Plow, 540 4 Bottom Semi-mounted Plow, 12' 370 Disc, 18' 470 Disc, 18' 45 Field Cultivator, and 12' 2 Section Spike Tooth Harrow. Also lots of IH Toy Tractors.
Also have a black sheep; an AC 7045 and it stays in the shed.
My avatar is a spittin' image of my Golden Retriever "Sadie"
#9 CNKS
CNKS
  • Members
  • PipPipPip
  • 643 posts
Posted 24 April 2008 - 06:01 PM
I would call the 330 a hybrid. It really has more similarity to the 300/350, same configuration along with a TA and 5 speed transmission. But, the C135 is an upgraded A/B/C through 240 engine.
