Whats The Difference?
7 replies to this topic
#1 redneckchevy9
redneckchevy9
  • Members
  • PipPipPip
  • 184 posts
  • Gender:Male
  • Interests:My Lovely Girls, IH Tractors, Antique Tractors, Chevy Trucks, Farming, Anything IH, Draftsman & Boom Truck Driver For Area Lumberyard
Posted 05 March 2008 - 12:44 PM
I have looked all over the internet trying to find out what the real difference between a C & a Super C is. I know that the Supers had a 123 in them,but besides that, are they any other differances? May sound like a dumb question to most of you - its just driving me nuts.
#2 MNredfarmer
MNredfarmer
  • Members
  • PipPipPip
  • 2,442 posts
  • Gender:Male
  • Interests:400LP,400D,685,706LP,706GD,ST270Steiger,'64 1600CO,'711800loadstar,761800loadstar,5140,5088
Posted 05 March 2008 - 02:23 PM
The C had the 113, SC had the 123.
The SC had a water pump, the C didn't.
The SC had a taller radiator I think and the grill was taller also.
Every SC I've seen had a live hydraulic outlet on them.
C,400LP,400D,CIH 685,706LP,706GD,5140,5088,
Steiger ST270,'64 1600CO,'71 1800 loadstar,
'761800 loadstar, 70 and 2 77 olivers,
2000 3/4T Silverado
#3 Michael Halsall
Michael Halsall
  • Members
  • PipPipPip
  • 1,459 posts
  • Gender:Male
  • Interests:Engines from TITANs to TURBO diesels.
    McCormick-Deering & McCormick standard tread tractors.
    Classic Crawlers
    IH Corporate History
Posted 05 March 2008 - 03:54 PM
Farmall C had a draw-bar style hitch. (Built 1948-51)
Farmall SUPER C had the "Fast Hitch" implement attatchment system. (Built 1951-54)
Regards from Michael H
#4 Colin
Colin
  • Members
  • PipPipPip
  • 986 posts
  • Interests:All red power on our farm<br />
Posted 05 March 2008 - 04:19 PM
The Super Cs have disk brakes like there bigger brothers, the S-H and S-M
the later ones most likely had all coil ignitions. allthough our 52 SC has a mag? seems like 51 or 52 was the end of the mags on all our other tractors. i didn't realize the odler Cs didnt have a water pump. and i know the Super Cs have the same gen belt as an MD. also the Super Cs and maybe the later C's have the front rims that bolt on vs the ones that hold on with the 3 cast pads. although some older farmalls had the later style. (our BN is like that) does anyone know if the SC is gear faster? the Super H's and M's are.
Our Tractors Etc.
'75 1066 w/ ldr, (2)66 Int. Std-1206 w/ Duals, Wheatland 806, F-706(cab, duals,german diesel) F-560D, 650 w/cab,Super WD9, WD9, W9, W450D, W450G, W400D, W400G, Super W6TA D, Super W6TA, Super WD-6, Super W6 #507, WD6, W6, Super W-4, W-4, Super MTA Diesel, Super MD n-f, Super M(backhoe), MD, M, S1 Super H, H, Super C, BN,'54 Super A, Cub *WD-40 & W-40 on road steel, W-30, I-12, '50 TD9, '56 TD6, 22-36, 15-30, 10-20, (2)175 sp swather 13.5 & 16', IH cultivators ** Extras '41 M on steel, '41 W-6 on Rear Steel(made in '40) '52 SWD6, '53 Stage 2 SMD wf, '53 Yellow SM, nf. ** Latest W-4, 1953 #33999(Sold Oct'10)** *Wanted: MTA project tractor
#5 fatjak
fatjak
  • Members
  • PipPipPip
  • 254 posts
Posted 05 March 2008 - 04:22 PM
:P i have seen the service bulliten were they had a better camshaft.
#6 234-IA
234-IA
  • Members
  • PipPipPip
  • 1,250 posts
Posted 05 March 2008 - 05:11 PM
Supers were generally heavier built than straight Cs and had an upgraded steering setup including a larger diameter steering wheel.
We have a '51 which has only Touch Control, no FH or hyd outlet-- I believe they weren't available 'til 1953 or so.
Great little tractor, they run like sewing machines...
#7 Farmall Randy
Farmall Randy
  • Members
  • PipPipPip
  • 238 posts
  • Interests:Farmalls<br />
Posted 06 March 2008 - 08:28 AM
Some visual differences the brake and clutch petal are curved or bent on the SC and are straight on the C. There will be a temp gauge for the touch control oil directly in between the touch control levers on the SC, the gas tank is visibly higher on the SC you can see daylight between the tank and the hydraulic assy thing(don't know the correct terminology)
Dont know if you can see it without the tractors side by side but the steering rod angle was changed also, to accommodate the larger steering wheel I think
Randy
#8 Super A
Super A
  • Members
  • PipPipPip
  • 2,879 posts
Posted 06 March 2008 - 08:58 AM
Early Super C's didn't have fast hitch. That came in '53 I believe.
Al
"Let us pray for farmers and all who prepare the soil for planting, that the seeds they sow may lead to a bountiful harvest." Super A x 2, 424, 230,  Cub, 52R combine, R-160 truck, 856 D, Super A-1, White Demo Super A, 5 geese, and 11 cats
Reply to this topic
