HyTran vs "Universal" power fluids
17 replies to this topic
#1 guypatrick
guypatrick
    Member
  • Members
  • PipPip
  • 18 posts
Posted 28 May 2007 - 06:39 AM
Could someone point me to some research or statistics which compare the properties of various hydraulic fluids?
We're trying to justify the cost and effort of switching nearly everything over to IH Hytran but I'd like to see something more overwhelmingly convincing than I've been able to find to date. Of course the dealer recommends Hytran but they haven't been able to show me quantitative evidence why its better. I will grant that "Its what the manufacturer recommends" is a valid arguement but I'd like to know why its better, or different.
We did have problems with the hydrostat in a Rogator loosing power at higher operating temps a couple years ago. The manufacturer suggested switching from a universal product to a different oil (iso 100 I think) which improved the performance significantly so I have no trouble beleiving there ARE differences I'd just like to know what they are.
#2 Rick G.
Rick G.
  • Members
  • PipPipPip
  • 4,331 posts
  • Gender:Male
  • Interests:IH, Farming, Aviation enthusiast, Astronomy, NFL, Country Music, Shania Twain
Posted 28 May 2007 - 07:11 AM
I don't have any statitics or research to go by except this: My neighbor uses CASE IH HYTRAN in his JOHN DEERE 4430 tractor and 7720 combine when we need to add hydraulic fluid to those 2 vehicles. :blink: He keeps HYTRAN around for his 1086, 986, and 766.
I use my own stash of CASE IH HYTRAN if I ever need to add hydraulic fluid to my 1456, 1086, or 7220.
As a related side tid-bit here, one of my local IH techs advises me to "over-fill" my 1456 and 1086, (and I think I remember reading this advice here on the board before as well) so I keep my 1456 and 1086 between 1" to 2" above the full mark on the dip sticks.
As for my 7220, I watch to keep it right at the full mark.
My tractors themselves do not leak, but I'm afraid I'm losing fluid little by little through the various implements that I use, whether they be mine or my neighbor's.
Rick G.
Tractor owned: 1976 IH 1466 Black Stripe, Serial # 30313
#3 Maynard
Maynard
  • Members
  • PipPipPip
  • 3,355 posts
  • Gender:Male
Posted 28 May 2007 - 07:54 AM
Rick, Your neighbor is taking a huge risk using Hy-Tran in a John Deere tractor.
The water retention property of Hy-Tran (and some other fluids) can cause the paper friction material in the Perma Clutch and power shift clutches to de-laminate.
Hy-Gard is also a heavier fluid than Hy-Tran. Hy-Gard is designed to completely reject water whereas Hy-Tran is designed to absorb a significant amount of moisture.
Other properties that Hy-Tran does have is a seal and o-ring swelling agent that many universal fluids lack.
Anti-foaming and the ability to rid itself of air are properties that make Hy-Tran superior to many universal fluids. (High performance power steering fluids are nothing more than re-packaged Hy-Tran)
One example where I demonstrated to a customer the value of the swelling agent....I was doing a T.A. job for an owner who refused to use anything but the least expensive oils he could find.
When I got to the part where the T.A. jumper tubes were to be removed I flipped them out with my fingers.
I then tossed the tubes with the o-rings still on them into a pan of Hy-Tran I used for soaking PTO clutch plates.
After 10-15 minutes I took the tubes out of the Hy-Tran and the o-rings had swelled enough that they had to be forced into the same holes that they had just slid out of.
The owner was there while I performed this demonstration. He finally changed his mind about our fluids.
Jim N.
Growing Old Is No Excuse For Growing Up
"Yet people are considered to be "educated" after they have spent so many years in ivy-covered buildings, absorbing the preconceptions that prevail there."
Thomas Sowell
Being happy doesn't mean everything is perfect. It means you've decided to see beyond the imperfections.
"When people get used to preferential treatment, equal treatment seems like discrimination"
Thomas Sowell
#4 BOOMER
BOOMER
  • Members
  • PipPipPip
  • 3,698 posts
  • Gender:Male
  • Interests:Anything IH Red or Ford Blue
Posted 28 May 2007 - 08:20 AM
HELLO ALL, MAYBE IT'S JUST ME BUT IT SEEMS THIS TOPIC COMES UP A LOT ON HERE. I GUESS FOR MYSELF I WOULD NOT THINK ABOUT TRYING TO SAVE A BUCK IN AREAS WHERE IT CAN DAMAGE STUFF EITHER RIGHT AWAY OR DOWN THE ROAD. YEAH I KNOW IT WOULD BE NICE TO GET SOMETHING IN WRITING TO SHOW BUT I THINK ALL THE FEEDBACK YOU WILL GET ON HERE IN FAVOR OF HY-TRAN SHOULD BE GOOD ENOUGH. BOOMER
1938 Farmall F-20  , 1954 Farmall Super M-TA Gas, 1959 Farmall 560 Turbo Diesel with Woods belly mower , 1967 Farmall 656 Hydro Diesel , 1969 Farmall 856 Custom Turbo Diesel with a Westendorf loader & Hiniker Cab
#5 axial_al
axial_al
  • Members
  • PipPipPip
  • 683 posts
  • Gender:Male
  • Interests:F-14,H,400G,560D,756D,1086,8920,MX120, 2366,Massey 44.
Posted 28 May 2007 - 09:56 AM
In addition to the water absorbing and seal swelling properties of HY-TRAN, I learned at a Case-IH lube meeting once that the HY-TRAN is a straight 10W oil while most universals are multi-grade. In our area, this really makes a difference in the winter time where our chore tractors are stored in unheated sheds. I agree, it may cost more, but you can pay me now or later IMO. Good luck.
#6 oakvalleyacres
oakvalleyacres
  • Members
  • PipPipPip
  • 637 posts
  • Gender:Male
  • Location:West Central Wisconsin (Waumandee), by the Mississippi
  • Interests:RED IRON!!
Posted 28 May 2007 - 11:08 AM
Rick G.
Rick, The over filling is very important if you have any hills. Once the tractor tips just a little, there is no fluid in the up hill axle housing and the bearings get dry quick. I was always told 5 gallons over full was plenty. It is also a good idea to check the calibration of your dipstick. Just take off the casting where the top link of the 3-point attaches, and look at the end of the axles. The fluid level should be at the centerline of the axles on level ground and the dipstick showing full. When I got my 1486, the dipstick was showing full, but the oil was over 5 gallons low!
I use HyTran. When was the last time anything marked "Universal" worked for everything?
Erik
Farm with '50 M, '53 Super M, '54 SMTA, '68 706, '70 826 Gold Demonstrator, '70 1026, '68 856, '68 1256, '70 1456, '76 966, '76 1066, '75 1466, '76 1566, '77 1086, '81 1486. And, yes, I do have one green one - '65 4020- and it's for sale!.
Raise Black Angus in a cow/calf operation.
Railroad Mechanic by trade, I.A.M. Local #112.
#7 Rick G.
Rick G.
  • Members
  • PipPipPip
  • 4,331 posts
  • Gender:Male
Posted 28 May 2007 - 12:07 PM
Jim N.
Yowza Maynard! :o
Thanks for the info. I'll inform him quickly about this, including the details and reasons that you've mentioned here! Then, it'll be up to him to take action on this. Thanks.
Rick G.
Erik
Erik, OK, no hills or slopes here for me to worry about, I'm working all flat ground, so I guess I'm in good shape as far as that goes.
Thanks, Rick G.
#8 826BB
826BB
  • Members
  • PipPipPip
  • 61 posts
  • Interests:4x4s, old trucks, farming and tractors.
Posted 28 May 2007 - 02:16 PM
To be honest, I'm not convinced that Hy-Tran is the end-all-be-all. At least Maynard had some useful facts in his post instead of the usual subjective commentary, which was a nice change. The oil level info is also useful. Thanks for both items.
I went round-n-round with this topic three years ago and did a lot of research but gleaned few worthwhile facts. Could not even get enough formulation info on Hytran, and other fluids, to look at it from the tribologist's perspective. In the end, I drain the decades old fluid from my newly purchased old tractor and replaced it with a "premium" universal rated for use in IH tractors. My choice... my responsibility. In fact, I noticed an improvement in all hydraulic functions. That's as much to do with the ancient fluid being replaced as anything else, I realize, and who knows if it was Hy-Tran or not.
My plan is to have this fluid analyzed at the end of this season (three seasons in use) and see how it's held up. I'll make my decision then whether to replace it with a similar universal fluid or Hy-Tran. If nothing else, it will be a good flush oil, huh?
One thing I noted was that at two CaseIH dealers near me, their bulk fluid is NOT Hy-Tran. One was a Mystik product and the other Shell, if I recall correctly. Makes you wonder.
I'm more than willing to be convinced, but for now the difference in price between Hy-Tran and the better universal fluids is keeping me at bay without more facts upon which to make an educated choice.
Jim Allen
NW Ohio
'70 Farmall 826D, 8200 hours and counting
#9 Sparky
Sparky
  • Members
  • PipPipPip
  • 2,577 posts
  • Gender:Male
Posted 28 May 2007 - 03:16 PM
............. I agree, it may cost more, but you can pay me now or later IMO. Good luck.
What axial_al said says it all. I use Hy-Tran, you really can't go wrong putting in what the manufacturer recommends, can you? ;) Besides, lately it seems around here that Hy-Tran is less than $1/gal higher than the "best" universal fluids.
Travis
'74 966, '46 H, Two 990 mower conditioners, #15 rake and a #35 behind it, 241 bigroll baler, 560 plow, #37 disc, 19' 45 F.C. and a couple other off breeds. Got a 782 Cub Cadet, also. Not much else, but it keeps me out of trouble!
Money is NOT the root of all Evil, Lack of money is the root of all Evil...
#10 Detroit
Detroit
  • Members
  • PipPipPip
  • 3,551 posts
  • Gender:Male
  • Interests:I've got a 1206 and a 1468. Olivers, Molines, and Massey. And a 7520 Deere.
Posted 28 May 2007 - 03:20 PM
We run tractors made by 9 different companies. There's no way that I'm keeping 9 different kinds of oils in my shop. Heck, over half of the brands of tractors we run aren't even in business any more. What am I supposed to do with them? I'll tell you, buy the best quality oil in bulk and go with it. I'll run over to JD or CIH and buy a 5 gallon or two of oil if I'm in a bind and need some quick like I was one day last week.
Call me crazy but thats the way I feel about it. Buy a good quality, brand name oil and be happy with it. That stuff in Wal-mart in the yellow jugs just doesn't cut it for me.
One of the best things we ever did was put a blue dye in our hyd. bulk oil tank. It was always amazing how hydraulic oil and motor oil looks and smells the same in a 2.5 gallon jug. Now its easy to tell the difference.
Go Hogs Go!!
Reply to this topic
