A question for you 1066 tractor pullers
18 replies to this topic
#1 956xl-uk
956xl-uk
  • Members
  • PipPipPip
  • 223 posts
  • Gender:Male
  • Interests:IH tractors(restoring 434)
Posted 11 February 2007 - 01:25 PM
Hi, all
A friend of mine is thinking of buying a 1066 for tractor pulling over here in the uk.
Can anyone tell me what the technical specifications of the standard farm tractor are and what the specs are for a average 1066 pulling tractor.
What are the usual modifications done.
Cheers Ed
Running ih 434, ih 674 ,Case-ih 885 , Case-ih 956xl D358 (13,000 hours), Ford 7840sle ,Newholland 7740/moffett, Massey Ferguson 4455, Mccormick MTX150.
IH tractors owned in past, B250, 434, 454, 574 and 1055
#2 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,500 posts
  • Gender:Male
  • Interests:Rebuilding IH farm tractors, Pulling RED tractors, Working in my shop. MOPAR cars. Austrailian Opals
Posted 11 February 2007 - 02:37 PM
Engine specs are
414 ci 4.3"bore 4.75" stroke, Wet sleeve, oil cooles pistons, crank driven oil pump, cross flow head. Rated at 125PTO HP.
The transmission is a 4 speed sliding gear with a high and low plus a two speed hydraulic direct and under. Has a total of 16 forward speeds with the "torque amplifier "
Shipping weight of the tractor is about 13,000#
The modifications depend opn the class and the rules you pull under. If you pull in a "stock farm" class just opening the fuel pump should get you into the 250hp range. From there the sky is the limit as far as modifications. A easy hp gain is to change the crank and pistons to go to 466CI. The stock model 100 Bosch pump and injectors can be modified for significant HP gains to the 450 to 650 hp range with turgbocharger mods and changes.(approx). From there a inline fuel pump will deliver MUCH more fuel and more reliably than the rotory stock pump. With a inline pump and proper porting,cam changes, and a BIG charger 1000HP and MUCH more can be had. These tractors seem to be able to handle quite a bit of HP in the normal weight classes. There are several companys here in USA that specialize in IH pulling parts. Or you could buy mine!??
"Rooster" 1066 puller tractor, Soon to be turned back into a farm tractor
 "Banty" 666 7000# Puller toy, 312 3-LM Has stuff done to it.
"Emmy Lou" 1939 M , 1939 Farmall H (to be named later)
'  F-1206, 2WD 5088  1066 to be restored
2 782 Cadets 1 repowered. CanAm OutlanderMax650
2 Dodge Cummins trucks 2013"Buckweet" and 2004 "Duke"
[i][color=#FF0000]
Can am outlander Max, XT Honda ST 1100
Torchmate CNC Plasma cutting table
#3 956xl-uk
956xl-uk
  • Members
  • PipPipPip
  • 223 posts
  • Gender:Male
Posted 11 February 2007 - 02:57 PM
Engine specs are
Hi,
At 650-1000hp,man thats impressive, what stops them from blowing up?!!!!!!!!!
Ed
#4 lance358436
lance358436
  • Members
  • PipPipPip
  • 590 posts
Posted 12 February 2007 - 12:18 PM
Ed
[/quote]
Well I would say it not a farm tractor anymore dont put alot of hours on it.
Good luck on you tractor pulling.
red toys for me please.
tractors I have 79 1486,72 1466, BS 1066, 1206, 2/ 70 826's and a AC D-17
tractors dad has 7240, 7130 ,old 1486,new 1486, 70 ih826 , CU german 756, gas 706, AC D-17
If it was easy everyone would do it.
Owner of Donlon Enterprises LLC
Tractor and machinery repair
I know my 6.2-6.5T GM motors too.
#5 Cliff Neubauer
Cliff Neubauer
  • Members
  • PipPipPip
  • 4,539 posts
Posted 12 February 2007 - 12:23 PM
Ed
They only run that hard for a few seconds at a time and there is alot of money put into them to help hold them together.
Cat 55, MX-240, 5488, 1086, 1066, 1066, 1066, 5140, 826, 706, 656 Hydro, 450, M, M, M, SH, 100, 70, 1724 and KB-5 IH trucks.
#6 1206SWMO
1206SWMO
  • Members
  • PipPipPip
  • 2,707 posts
Posted 12 February 2007 - 06:47 PM
Posted Image
This IH is well over 2000 horses and sometimes they dont stay together.
#7 Cliff Neubauer
Cliff Neubauer
  • Members
  • PipPipPip
  • 4,539 posts
Posted 12 February 2007 - 06:55 PM
Here's another one that's gonna need more than an oil change before the next pull.
Posted Image
Posted Image
Posted Image
#8 stx450
stx450
  • Members
  • PipPipPip
  • 373 posts
  • Interests:Railfanning, Tractor pulling
Posted 13 February 2007 - 11:50 AM
The only Green ones i seen fly apart like that have been the Die Hard Deeres/Greenline Express They all were K&K built tractors Be interesting to see if they got their issues figured out
#9 lance358436
lance358436
  • Members
  • PipPipPip
  • 590 posts
Posted 13 February 2007 - 12:07 PM
If I thinking right the motor blow apart right about where the camshaft runs throw the block heard that is the weak spot of the 400 # motor. when running that much power.
#10 956xl-uk
956xl-uk
  • Members
  • PipPipPip
  • 223 posts
  • Gender:Male
Posted 13 February 2007 - 01:44 PM
Thanks for the cool pictures guys, I thought holding 1000hp together might be harder than you made it out to be! Here`s another question -Diesel engined pulling tractors put out **** of alot of smoke, how much of that is unburnt fuel and secondly has anyone ever used nitrous injection to get a better fuel/oxygen mix?
Ed
Reply to this topic
