M&W add-power governor
8 replies to this topic
#1 EJH1466
EJH1466
  • Members
  • PipPipPip
  • 677 posts
Posted 15 August 2006 - 11:57 AM
Guys,
I've been noticing a few M&W add-power governors on ebay lately. Did these work good? I've never ran a tractor with one on it before. Anybody have experience with one? What's different about them than a regular IH governor on an M or H?
Eric
1976 IH 1066, 1974 IH 1466, 1973 JD 4230, 1960 JD 730D, 1953 IH Super H, 1952 IH Super M, 1976 Gleaner L
#2 nosih
nosih
  • Members
  • PipPipPip
  • 949 posts
Posted 15 August 2006 - 01:40 PM
Personally I think they are not worth what they go for. The stock governor is just as good when kept in good shape. The only negatives that a stock governor has, is the weights & weight pins wear, and the springs often need to be replaced. Honestly they are not worth the cost in a restored tractor that may see a 0-10 hours per year. The only real benefit to the M&W is for pullers..
Dealer in NOS IH Tractor, Crawler, & Stationary Engine parts. Current Collection: 1905 IHC 2HP Veritcal Stationary Engine, 1910 Tom Thumb Stationary Engine, 1911 IH Autowagon, 1915 1HP Mogul Stationary Engine, 1915 Titan Jr Stationary Engine, 1918 VB Series 8-16, 1919 3hp Type M Stationary, 1922 IC Series 8-16, 1923 10-20, two 1939 Hs, '47 Cub, '51 Super AV, '51 Super C, '61 460, 666, 856D, Three IHC Garands.
#3 EJH1466
EJH1466
  • Members
  • PipPipPip
  • 677 posts
Posted 15 August 2006 - 02:10 PM
So, what's the difference mechanically between the two? What's the advantage in pulling?
Eric
#4 Dr._EVIL
Dr._EVIL
  • Members
  • PipPipPip
  • 1,447 posts
Posted 15 August 2006 - 02:13 PM
I'd even question the need for an AddPow'r governor on a pulling tractor. The reason M&W developed them was to allow faster response to increases in load so Your engine holds RPM better. Dad's '51 M has one and it does pickup RPM faster than the Super H which doesn't have one but then the SH runs faster and has more RPM to catch. Once the throttle blade in the carb is wide open that's all the governor can do.... but when plowing. discing, baling, etc. the governor gets a constant workout.
#5 supermpuller
supermpuller
  • Members
  • PipPipPip
  • 1,078 posts
Posted 15 August 2006 - 02:30 PM
Just put on a MW gov. on this year, its more responsive than stock gov. cost is about the same to rebuild old gov or get a MW kit.
#6 boog
boog
  • Members
  • PipPipPip
  • 7,722 posts
Posted 15 August 2006 - 03:54 PM
smpuller, Where did you find a rebuild kit for your M&W governor? I have one on a L-SM that needs rebuilt. Have found some individual parts but no kits. Guy I talked to said there were 2 different weights used, one still available but the other isn't.
TIA,
boog
IH tractors currently owned: '49 M, '52 SM, '53 stage 1 SM,  '53 stage 2 L-SM,  '54 SMTA, '66 806D w 2355 loader, co-own a '66 1206 with IHboog, store a '66 706 German for IHboog. IH / CIH equipmemt - ''13 Maxxum 115, 11 MX 275, '10 STX 435, '03 MX255, '14 7230 combine w/ 40' 2162 draper & 4412 ch,  '07 3310 sprayer,  '12 1250 16x30" planter, 12/23 1200 planter, 34' 330 True Tandem , 18' 870 , 7x16" 720 on-land plow, 6x18" 720 in-furrow plow, , #60 4X16" Plow, #1300 3 pt 9' sickle bar mower
#7 chaindrive1651
chaindrive1651
  • Members
  • PipPipPip
  • 509 posts
Posted 16 August 2006 - 12:42 PM
I've installed the Thompson X-TRA power gov kits in some "H" & "M" before with huge results.This is a 4 weight roller bearing gov kit that comes with all the parts you need to get good throttle responce.This will bring it to life compaired to the old two weight gov.
#8 supermpuller
supermpuller
  • Members
  • PipPipPip
  • 1,078 posts
Posted 16 August 2006 - 04:29 PM
TIA,
boog
Paul Marlatt 765-938-2227 can get parts for you.
#9 boog
boog
  • Members
  • PipPipPip
  • 7,722 posts
Posted 16 August 2006 - 08:24 PM
TIA,
boog
Thanks
