782 Cadet Repower or rebiuld?
14 replies to this topic
#1 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,448 posts
  • Gender:Male
  • Interests:Rebuilding IH farm tractors, Pulling RED tractors, Working in my shop. MOPAR cars. Austrailian Opals
Posted 03 May 2006 - 08:52 AM
My nicer 782 was run without proper air filteration at some time in its past and the engine got "dusted". It burns lots of oil but runs very smooth. I am debating the merits of a Honda repower over a rebiuld or Kohler replacement. Any intellegent thought about this out there?
"Rooster" 1066 puller tractor, Soon to be turned back into a farm tractor
 "Banty" 666 7000# Puller toy, 312 3-LM Has stuff done to it.
"Emmy Lou" 1939 M , 1939 Farmall H (to be named later)
'  F-1206, 2WD 5088  1066 to be restored
2 782 Cadets 1 repowered. CanAm OutlanderMax650
2 Dodge Cummins trucks 2013"Buckweet" and 2004 "Duke"
[i][color=#FF0000]
Can am outlander Max, XT Honda ST 1100
Torchmate CNC Plasma cutting table
#2 MAGNUM
MAGNUM
  • Members
  • PipPipPip
  • 3,193 posts
  • Gender:Male
  • Interests:all IH tractors over year 1960, i have a restored 1466 open station,a 1966 1206.cub cadets, model 86,108,109,129,149,1210,1710,782
Posted 03 May 2006 - 09:32 AM
that engine can be expensive to rebuild, maybe look at getting a kohler command engine if you are going to replace it, the command engine is a v-twin with over head valves, will have to do some fabrication but it will be alot better engine than the kohler magnum
i own a restored 1971 1466,one of the first off the line open station,a 1206,open station,#8917. plus restored cub cadet's 86,108,129, and a 1710,(not restored),782 w/3pt an just got a 149 hydraulic lift and 3pt.just got a 1210 w/44" deck
Either make excuses or make an effort and find a way, one makes things better,the other does not.
#3 Ernest
Ernest
  • Members
  • PipPipPip
  • 5,015 posts
  • Gender:Not Telling
Posted 03 May 2006 - 09:36 AM
Is the KT kohler a series 1 or 2 with oil filter? If it is series one without pressure lube I would concider the honda conversion or M-18 kohler. Because the engines were great mowing flat but on hill sides which ever piston was up hill gets starved for oil and makes a window in the block in due time. If series 2 with pressure lube I would try a rebuild it since it only burns oil and runs smooth. You may be able to get away with just honing the cylinder and new rings? But you can only tell when open it up. I do know parts are expensive for the KT-17 kohlers. Another thing guys are doing is installing the Magnum kohlers M-18 only difference is electronic ignition ane full pressure lube. I believe most internal parts interchange. The engines look identical from a quick qlance.
Magnum
Did not know the command would work. I know they are good. I believe thats what the 1541 cub cadet has in it that my grandfather has?!
#4 MAGNUM
MAGNUM
  • Members
  • PipPipPip
  • 3,193 posts
  • Gender:Male
Posted 03 May 2006 - 10:07 AM
ernest, the cub i mow with is a 1710 with a series 2 the 782 i just got last summer had a series one in it and the ran it out of oil, i talked to the guys at our other store and they said to put a command in it, it will work but you do have to do some fabrication, cant remember what. but they lost a tractor off the back of one of the delivery trucks and i got the engine out of it, and put in the 782, its a series two 18hp, with oil filter, almost wish my 1710 had an oil filter. the put in a 15hp command in a 482 they did a nice job on it.
#5 DavidH
DavidH
  • Members
  • PipPipPip
  • 116 posts
  • Interests:Tractor pulling, garden tractors, wife, and son!
Posted 03 May 2006 - 02:53 PM
<{POST_SNAPBACK}>
[/quote]
The 1541 had a M18 Magnum. I think I heard once that they put a different carburetor on it to derate it from 18hp to 15 hp. My grandmother has one, it's a good tractor only hard to start when cold.
#6 489gus
489gus
  • Members
  • PipPipPip
  • 33 posts
Posted 03 May 2006 - 04:50 PM
I did a 22hp command about 2 yrs ago on a 782. Runs good when it starts. Takes a little cranking to start those kohler commands. I have asked a few lawnmower mechanics about the long cranking - yep they start hard.
If i would do it again, i would try the 18hp v-twin honda. I sure like how our honda pressure washers starts.
Here is a link of where I got my kit.
http://www.smallengi...610K0-IH682/782
#7 gonzo 1066
gonzo 1066
  • Members
  • PipPipPip
  • 6,448 posts
  • Gender:Male
Posted 03 May 2006 - 07:52 PM
The small engine warehouse is the place I was looking. Seems like a good deal. Ordered one, hope this is the right decision. I just know that the Kohler is not going to hang on a rebiuld stand in my shop.
[i][color=#FF0000]
#8 red_reaper
red_reaper
  • Members
  • PipPipPip
  • 8,967 posts
  • Gender:Male
  • Interests:my tractors,steiger panther 310,1456,782,656,SC, 756,1206 V8,2-1206Farmall's,5488,2166,560,806,7240, Gold demonstrator 312 fast hitch plow. HSWJ
    familytractors,H,H,SM,504,544,656,656,666,MX,686,706,1206,1206,806,806,1086,460,1086,8940,1586,1586,7150,325 stieger 2366,2388,Steiger 380,5240,826
Posted 03 May 2006 - 08:39 PM
I put a kohler replacement KT17 I believe is the number in mine after the rod went through the original non oiler engine. This one has remote filter that I mounted in front. I am happy with it and have almost 300hrs on it since changeout,and everything bolted in just like the old one. The new engine might have 18hp I cant remember,but I use a 50" deck on it and I had to mow my pasture of a yard yesterday and it worked fine in that tall stuff.
The farmall resurector. Bringing them back from the dead.
my tractors,steiger panther ST310,1456,782,,656, 756,1256,1206 prototype,2-1206Farmall's,1206 V8 powered, 5488,1460 combine,SC,560,5088 experimental demonstrator, 312 fast hitch gold demonstrator plow.IH 3F cream separator.
familytractors,H,H,SM,504,544,656,656,666,MX,686,706,826,1206,806,806,460,560,10
CM325 stieger, 2010 model 385 Steiger, 2366,2166 combines
#9 Bermuda_Ken
Bermuda_Ken
  • Members
  • PipPipPip
  • 4,341 posts
  • Gender:Male
  • Interests:IH & Kenworth literature, O-scale trains.
Posted 03 May 2006 - 09:15 PM
This same question was just asked on one of the Cub Cadet forums. Here is my statement posted there............."Don't get the Honda from S.E.W. In a few years when they switch to the next "great buy" they get (like in the past) the Honda won't be supported by them for parts. Your CCC dealer definately won't know ANYTHING about it either......Buy from an American Company, Buy Kohler!"
Get the RED EDGE......the IH Edge.....working for you!
Still looking for a IH 4300 Transtar Eagle Brougham Truck!! (like the one in the photo)
IH's owned past & present.......F-1206, F-806 sn# 501, CC Original # 522, CC Original(s), Spirit of 76 Cadet, 126, 1450, 1200, 1610 CADET prototype, 1250(2), 782(2), 782-Diesel(2), 982(2), 1912 & More!
See the LARGEST FREE listing of Modern IH tractor wiring diagrams on the internet (at least for now) by clicking....IH Tractor Wiring Diagrams
Visit the IH dealership I work at, Johnson Tractor (2012 Dealership of the Year) in Juda, WI......... www.johnsontractor.com
Contributing author for Red Power, Classic Farm & Tractor, Heritage Iron and Classic Tractor magazines. IH Tractor book author for Motorbooks, Voyager Press & Octane Press.......BUY A COPY & Read a book!!!
#10 bindernut
bindernut
  • Members
  • PipPipPip
  • 3,342 posts
  • Interests:old tractors, wood working, and causing trouble.... and not neccessarily in that order.
Posted 03 May 2006 - 09:53 PM
I wonder how long it'll be before MTD riders(cub cadet, troybilt, yard man, etc) get Honda engines. They already use honda engines for some of their push mowers, along with Kawasaki. in fact, those are the only 2 engine makers that cub cadet pushmowers use, according to their web site.
You want a good engine, get a honda or Kawasaki. The Honda will probably cost more, but neither are cheap, and both are good engines.
Where I work, we sell & fix any & everything. The new kohler's are crap! If you want American, buy a Briggs. Good engine, less $$$ than honda or Kawasaki.
I've got an old Cub Cadet 129 with a 12 HP Kohler. I love that mower. I can flog the piss out of it and it just keeps coming back for more. But I wouldn't buy a new mower w/ a Kohler.
Mark
Down the hole is down the hole. I might as well have some fun along the way!
We're getting the band back together!
The only easy day was yesterday.
I may not agree with everything you say, but I'll defend to the death your right to say it."
Reply to this topic
