starter on international 300 utility tractor
5 replies to this topic
#1 pats47BN
pats47BN
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 08 April 2006 - 06:02 PM
installed rebuilt starter on tractor this afternoon. only one problem. once i connect the battery the starter runs and runs even with ignition switch turned off and key removed. could this be aproblem with the switch or could starter wires be installed incorrectly?
#2 f 20
f 20
  • Members
  • PipPipPip
  • 140 posts
Posted 08 April 2006 - 06:29 PM
solenoid stuck on?
4366 706d 706g 560d 460d smta sm m 350u f20 b 234 and 2mh pickers fast hich plows 56 planter 1700 loadstar and more. est.1873. hoosier homesead. t 20 td9
#3 pats47BN
pats47BN
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 08 April 2006 - 07:07 PM
solenoid stuck on?
<{POST_SNAPBACK}>
new solenoid with rebuilt starter i installed. could i have wired the new starter on wrong ? i put battery cable on solenoid and ignition wire on starter.
#4 mmi
mmi
  • Members
  • PipPipPip
  • 2,281 posts
Posted 08 April 2006 - 09:33 PM
keep us updated
Had 1 rebuilt 10 years ago,inferior parts correct was /is not available,or stocked wrong
never did fix had to put shut off in feed wire
would turn on any time
would try to start @ night or drive off if in gear during lunch
#5 pats47BN
pats47BN
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 08 April 2006 - 09:47 PM
keep us updated
<{POST_SNAPBACK}>
thanks for the info. mmi. i am gong to the local Case dealer on monday to try and get a new 4 wire ignition switch. old one looks pretty bad. if that's not it i'll take starter back off and return to rebuild shop. do i have the wires on correctly? 2 wires from ignition, one on small screw on solenoid and one on front of starter and battery cable to solenoid?
#6 TDK8
TDK8
    Member
  • Members
  • PipPip
  • 14 posts
Posted 08 April 2006 - 10:59 PM
keep us updated
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
The sol. mounts on starter and a copper strap attaches from sol. to starter post. Battery cable & small (red) wire to other large post on sol. The other wire(orange) goes to small post on sol. marked (S). There is no wire that attaches to starter directly.
