F Series Road Gear
13 replies to this topic
#1 IHMAN3388
IHMAN3388
  • Members
  • PipPipPip
  • 393 posts
Posted 22 October 2005 - 03:28 PM
:blink: How was the Road gear handled by Farmall in the F-series?
Was the road gear was in every transmission but locked out by a bolt at the factory unless Rubber was ordered?
Thoughts?
IHMAN3388
[B][I] IHMAN3388
Owner and keeper of hundreds of red power farm toys, dealer promos, jackets, posters, binders, price books. A wide variety of Red Power lore.....worker at www.outbacktoystore.com. One of the largest farm toy stores in the continental 48 states.
#2 superdaughter
superdaughter
  • Members
  • PipPipPip
  • 818 posts
Posted 22 October 2005 - 06:19 PM
We have two 1939 models and they both have road gear in the right-forward position which was previously the location for 3rd gear.
#3 axial_al
axial_al
  • Members
  • PipPipPip
  • 699 posts
Posted 22 October 2005 - 08:24 PM
Dad had a 1935 F-20 that had the fast fourth gear in the upper right position. It was handy...you could start out in third, then shift to fourth by double clutching and shifting with your right foot!
#4 Farmall Power
Farmall Power
  • Members
  • PipPipPip
  • 3,966 posts
Posted 23 October 2005 - 08:24 PM
The F-12 and F-14 had a 3 speed trany, they could be specially ordered with a 6 or 9 mph road gear. Heisler (sp) also made a 2 speed for the F-12-14-20-30.
Jeremy
I own, 1957 A100 Golden anniversary, 1967 1100, 1972 1110, 1973 1210 IH pickups
10, f-12's, 2 F-14's, F-20nt, W-12. W-6, M, A, 600d sn: 2012,plus #2 little wonder plow and several little genius plow. NO:9 mower on rubber.
Farm with 7140 MFD, 3688, F826D and what ever else is on the lot or handy.
03 ram 3500, 600 HP and counting. 97 ram 2500 with a few mods. 82 vw diesel jetta.
2000 w900 kw , 98 w900 kw 75th anv.edition.
Ex technition for the red army. Farm, run a repair- restoration shop, trucking company .
#5 Old-F20
Old-F20
  • Members
  • PipPipPip
  • 3,919 posts
Posted 23 October 2005 - 09:30 PM
<{POST_SNAPBACK}>
yep, sure can. ive got two 20's with the 'high speed trnasmission' in them where 4th is in the upper right position. thinking of putting a Behlen overdrive on one to see how fast we can go :blink: :P
"It takes less time to do something right than it does to explain why you did it wrong" Grandmas advice
GENIUS BY BIRTH, SLACKER BY CHOICE
#6 Farmall Power
Farmall Power
  • Members
  • PipPipPip
  • 3,966 posts
Posted 23 October 2005 - 09:33 PM
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
neighbor had a F-14 with the 9 mph road gear in it and he had a 2 speed on it too :D He said i would do 25 really eazy :D :D :D :D :D :D
Jeremy
#7 Old-F20
Old-F20
  • Members
  • PipPipPip
  • 3,919 posts
Posted 23 October 2005 - 09:37 PM
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
Jeremy
<{POST_SNAPBACK}>
im just thinking for a tractor ride deal. wouldnt have to run the engine up so fast to keep up. that and smoke the JD boys :D they already hate me though :blink:
#8 Bobcat
Bobcat
    Member
  • Members
  • PipPip
  • 23 posts
Posted 24 October 2005 - 07:08 AM
Hey Old F-20, The internal overdrive won't add any speed to the add-on box on a F-20, Regular,or F-30 because you shift the transmission into neutral and then engage the box to go into overdrive. Out- run the green one's! I like the way you think!
The F-12/14 box will double up the input shafts speed or more depending on the ratio in the box. That is why it is recomended that the pulley be removed from the tractor.
Does anyone have a F-12 box that is quite? I have one but sure makes a lot of whinning when in overdive. My 12 is on steel and will not even pull itself on level ground in 3rd High.
#9 Farmall Power
Farmall Power
  • Members
  • PipPipPip
  • 3,966 posts
Posted 24 October 2005 - 10:45 AM
<{POST_SNAPBACK}>
I was just going to say that but you beet me to it :D
I have 3 of the heisler 2 speed boxes for the f-12-14, only one is on a running tractor and it is fairly noisy, i would like to put the other 2 on another one of my running 12's to see how noisy they are. Why should the belt pully be removed, i have one on the F-12 that has the 2 speed. Also the 2 speeds i have all have the same ratio stamed on the box's tag, was there differn't speeds made ??
Jeremy
#10 Old-F20
Old-F20
  • Members
  • PipPipPip
  • 3,919 posts
Posted 24 October 2005 - 06:23 PM
ahh crap. i was thinking of the F-12 gearbox was the same as the 20's. looks like i was out of it when i thought that. :blink:
